E36 (1991 - 1999)
Old 07-12-2012, 10:27 AM
paulelmore paulelmore is offline
Mein Auto: 1992 BMW 318i
Tire Size Options For '92 318i
I have a nice '92 318i with ugly steel rims and plastic BMW hubcaps. I'm needing new tires so I'm wanting to get a nicer set of BMW rims off of Craigslist that has good used tires.
I'm currently running 195/60R 15's.
I know it's a 5 lug 120mm pattern.
How wide of a tire can I put on the car safely?
Can you do 16's safely without rubbing?
P.S. I'm not doing any high speed crazy driving. It's just a daily driver at normal speeds.
Old 07-12-2012, 10:32 AM
Hellawut??
Mein Auto: who knows?
Pleese geet teem 17's
17's are the best looking size wheel on our cars.
-Franklyn
Old 07-12-2012, 10:42 AM
Hellawut??
http://portland.craigslist.org/mlt/pts/3131243197.html
-Franklyn
Old 07-12-2012, 11:15 AM
hornhospital's Avatar
D'oh, You Kids!
Originally Posted by Eight Thirty View Post
Why are your recommending 5X112 (Audi) bolt pattern wheels for his 318? They won't fit.
And they're 18".
Quotes to live by:
Old 07-12-2012, 11:25 AM
Time2Fly's Avatar
Time2Fly Time2Fly is offline
Sometimes Out To Lunch!!!
Mein Auto: 1993 318i 1994 325i 1998
This is the size you need and not a bad set of wheels either.....
http://www.ksl.com/index.php?nid=218...d=0&search=bmw
or this
This is the same wheel and tire setup I have on my 318:
http://www.ksl.com/index.php?nid=218...d=1&search=bmw
These would look good also:
http://www.ksl.com/index.php?nid=218...d=5&search=bmw
Or these
http://www.ksl.com/index.php?nid=218...d=6&search=bmw
Old 07-12-2012, 11:28 AM
bmw-mania bmw-mania is offline
Mein Auto: BMW
NICE wheels..
Wrong bolt pattern..
dammit!
He's got the right idea tho.. Start scanning CL up there in PDX.
Look for a nice set of wheels.. Try to stick with stock..
Unless.. You find some real nice, high quality wheels.
example: BBS
You can do 16, or 17 inch wheels without problem..
and you should be able to do it on the cheap.
Find a style you like.. and go with it.
I have my wheel wells filled..
Currently on 245/45-R17 with 10mm spacers
http://www.tirerack.com/wheels/trmotorsport-wheels.jsp
http://www.tirerack.com/tires/tires....ilot+Sport+PS2
EDIT:
And they're 18".
when you're right.. you're right.
or this
Ugly ducks!
Maybe for a winter set.. and for how freeking much?
yikes..
Its not really that bad in the SL/UT is it (?)
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 07-12-2012, 11:37 AM
Time2Fly's Avatar
I don't know I just found them call the person and find out.
Old 07-12-2012, 11:45 AM
Mein Auto: BMW
Originally Posted by bmw-mania View Post
Ugly ducks!
Maybe for a winter set.. And for how freeking much?
Yikes..
Its not really that bad in the sl/ut is it (?)
Rhetorical..
Price is listed.. asking way too much.
Old 07-12-2012, 11:47 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
The width and height (i.e. aspect ratio) of the tire you can ultimately fit onto your car depends entirely on the wheels you end up using. Wheel diameter, width, and offset will all affect the size tire you can use. So, my recommendation would be to choose your wheels, and then figure out which tires will work best for them. As a general rule, 17" wheels are the best diameter for the E36, and you'll want to keep the offset between about 35-42mm.
1998 BMW 328is
1966 Pontiac GTO
Old 07-12-2012, 11:50 AM
Hellawut??
i suck.
lol
-Franklyn
Old 07-12-2012, 11:58 AM
Mein Auto: BMW
i suck.
lol
no no..
Good lookin out..
OZ!
Superleggera!
Real nice set of wheels... round peg, square hole.
318i, tires, wheels
