Oil consuming beast - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E39 M5 (1998-2003)
E39 M5 (1998-2003)
Old 05-05-2015, 04:45 PM
E39M5E46M3 E39M5E46M3 is offline
Mein Auto:
Oil consuming beast
I got a e39 m5 a few weeks ago and I've heard they consume oil like no one's business and I need to know when to change the oil. I may be an idiot for not waiting for the car to tell me but just in case id like to know about how many miles you can go on one oil fill up.
Old 05-09-2015, 11:35 AM
ard ard is offline
Resident Curmudgeon
7500 on good synthetic (10W60, TWS or liquimoly)
If the sticker says 5w30 ignore it
Old 05-13-2015, 11:36 AM
mark_m5's Avatar
mark_m5 mark_m5 is offline
Overly Intellectual
Mein Auto: 2002 M5, 2001 996 Turbo
I haven't checked my oil in ages. I think oil consumption is directly related to how beat up the engine is. If the car hasn't been thrashed, and has been well maintained, it should not consume much oil at all.
You might do a pressure test and leak-down test, and check for dripping leaks on the engine, if you're concerned about oil consumption. There are only a few ways oil can leave the engine. One is by getting by the rings around the pistons and getting burned (a sign you might need a rebuild), another is down valve guides and getting burned (new/rebuilt top end might help), another is through crank-case ventilation (though S62 has lower than typical negative pressure), and the rest are the various seals (valve cover gaskets, etc.).
Mark
Grammar: The difference between "knowing your sh*t" and "knowing you're sh*t."
"A world that is 'idiot proof' is a world that is only fit for idiots." - Racer X / 6'er
