Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M Series > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 07-12-2012, 09:53 PM
First_///M_'95 First_///M_'95 is offline
Mein Auto: 1995 m3 (e36)
Exclamation REally neep help right now!!!
Tonight i was rollin around through a neighborhood to look at a fire with my older brother, so we were proabably rollin about 25-30 in my '95 Bmw M3 that just reached 257k miles on her today and i look down at my dash and my temp gauge was redlinen. I started freking out because this car has been my dream since i was a kid and the last thing i want is the engine to blow! Ive been watching the engine area really closly lately because ive been hearin a "repeaded ticking sound" like it goes in revolutionsN every time i step on the gas it goes faster, so when i sit there and let it idel it dose the same thing but it dosent tick as fast. Anyway to the point, ive noticed im leaking alot of coolant from... well idfk and thats what i need help with, its covering everything thats right in front of the engine, especially the area where my flywheel is. theres alot of coolant in that area.
PLEASE HELP!!!!! ANYTHING HELPS HERE!
Where could it be leaking from ?
What should i replace?
Where should i go?
Mind you im working with my dream car here and its like im watching her tear herself apart and ya a enginge rebuild or just buying a brand new engine is already in the works, just dont know if i should get mine rebult or if i should just buy a new one, this m3 motor is really good i dont want to loose her just fix her and make her better.
Old 07-12-2012, 09:58 PM
Exclamation >>> ya that ticking
ok so that ticking is my valves apparently. Hopefully a easy fix? ha shiit. some one give me some good feed back here...........
Old 07-12-2012, 10:09 PM
wag-zhp's Avatar
wag-zhp wag-zhp is offline
Mein Auto: 97 White 328iC
Dude, do u like have A.D.D. or somechit or like what? Um, yeah like sounds like ur pumper of water is broke or something...
When it absolutely, positively, has to be destroyed overnight! OohRaah!!!
U. S. M. C.
Semper Fidelis
Old 07-12-2012, 10:17 PM
ahaha ummmmm"dude" why dose it matter ? look im just tryin to get some help here thats all i want. ight? dont start talkin that ish about add ? and what if i do "dude"?..... like i said i just want help THATS IT! N NOTHING ELSE!
Old 07-12-2012, 10:21 PM
wag-zhp's Avatar
I offered help, in your language even.
Check your water pump. (This is based on your rather indescript description of the problem.)
U. S. M. C.
Semper Fidelis
Old 07-12-2012, 10:40 PM
ohh damn man. MY BAD!! in that case............ THANKS! i really appreciate it!
Old 07-12-2012, 11:20 PM
Jon Shafer's Avatar
Admin • Owner • Enthusiast
Bimmerfest Founder
Mein Auto: E92 M3 Cp
Sometimes it is hard to trace where a coolant leak is coming from... What I am confused about is when you say "flywheel" and "front of engine"...
If it is up front, then most likely leaking from your radiator or expansion tank (e36 are notorious for this). Take it to a mechanic if you can't find it. They can do a pressure test to find the leak... Probably a good idea to check out water pump and thermostat as well...
Old 07-13-2012, 10:34 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
Better replace the entire cooling system, but before you do that, check to see if the head gasket is blown.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by EnserioJose View Post
Sorry. I'd imagine Seattle is a-hella-nother country.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
Old 12-06-2012, 03:27 PM
lovetherideUSMC lovetherideUSMC is offline
Mein Auto: e36 m3/ e30 325es
Yep mine has a slow leak into the engine... Got my self syked up for a head gasket r&r. Hopefully no cracks in the head/block! $550 for all parts amd tools. Well see what else pops up.
Old 12-07-2012, 04:29 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Water pump or radiator or a hose or thermostat housing. Those are normal places on these cars for leaks. When was the last time those items were replaced?
Water pumps are good for about 60 - 65K miles. Radiator and thermostat housing (plastic) are good for about 100 - 110K miles. Hoses vary.
And if went to redline on the temp gauge, yeah, check for a blown headgasket now or soon (head may have warped and the headgasket will go soon).
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 04-25-2013, 02:06 PM
Nline6's Avatar
Nline6 Nline6 is offline
Always best in the NW
Mein Auto: E39 528it & E36 M3 sedan
This^^^ BMW cooling system = FAIL. If you want your engine to last, keep it cool. That is all.
Touring the nation, one state at a time
Old 04-27-2013, 01:24 PM
EE05063 EE05063 is offline
Mein Auto: M3
275k miles.....I bet every part of the cooling system is tired. I would plan a complete overhaul. Radiator (I read the Z3M Coupe stock radiator is a bolt in upgrade), Water pump (get the kind with metal impeller), thermostat housing (get the aluminum one), expansion tank, all hoses and gaskets.....and lots of patience to make sure all air is burped.
OP, you might consider taking the time to compose yourself, it will help
Old 04-29-2013, 12:56 AM
tystager93 tystager93 is online now
Mein Auto: 1999 E36 M3
Re: REally neep help right now!!!
Along with what everybody has said I would also have a compression test done or cylinder head leakage test. And then again in 500 miles or so.
Do you know how long it was in the red? And has it ever been overheated before?
Sent from my Nexus 7 using BimmerApp mobile app
