E46 (1999 - 2006)
Old 07-15-2012, 04:18 PM
Jussybro Jussybro is offline
Alfa.M.twd.2012
Mein Auto: 06 325Ci E46 Coupe
Cool 06Coupe Sound Upgrade *HELP*
So I’m not 100% sure what option to go with to upgrade the stereo system in my 2006 325Ci E46 Coupe.
Factory features: SAT NAV wide screen, Tv, reverse camera (currently not working), Bluetooth mobile phone connection with steering wheel controls
I want to be able to play songs and watch vid clips and/or movies from a usb stick.
Thinking at this stage the “Dice Mediabridge MB1500” retailing on ebay for around $540 (pic#1)
www.ebay.com.au/itm/120694713699?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649
I want to be able to put my music on a usb stick and play it through my original head unit with song details appearing on screen, (if possible)
Also if I can not find a reasonable priced solution to my reverse camera issue, this unit should also accommodate an aftermarket OEM cam.
Can I achieve my goal with a cheaper alternative? (including vid clips, etc)
Anyone done so or is this mediabridge the one?
Moving onto the hardware of the sound sytem:
I’m thinking I will need the “PAC SOEM-4, Universal 4-channel line output converter” ($70) (pic#2)
http://www.ebay.com.au/itm/280489083...84.m1436.l2649
To hook a:
Boss PH4.600 4-Channel MOSFET POWER Amplifier 2400W Car Amp
($185) (pic#3)
http://www.ebay.com.au/itm/190648013...84.m1436.l2649
To Feed a:
Alpine S 12” Sub installed in a custom area typical to this,
($200) (pic#4)
http://www.ebay.com.au/itm/280418851...84.m1436.l2649
Then swap: the rear speakers out for something like this:
BMW 3 Series Front or Rear Door 13cm 2 Way 210 Watts Car Speaker Fitting Kit ($130) (pic#5)
http://www.ebay.com.au/itm/400304152...84.m1438.l2649
**A set of 6” splits in the front and maybe in the rear instead of previous option (2ways)**
These will be attached to these:
BMW 3 Series E46 Front or Rear 165mm Car Speaker Adaptor Plate
($40) (pic#6)
http://cgi.ebay.com.au/ws/eBayISAPI....vip=true&rt=nc
Is there a better way to achieve what I’m hoping with different modules etc.??
PLEASE HELP I VALUE EXPERIENCE AND OBJECTIVE OUTLOOKS.
Name:	Dice MediaBridge.png
ID:	332985   Click image for larger version
Name:	Pac 4 Chan.png
ID:	332986   Click image for larger version
Name:	Boss Amp 4chan.png
ID:	332987   Click image for larger version
Name:	Sub Boot Case.png
ID:	332988   Click image for larger version
Name:	Pioneer 2ways & adapt. plate.png
Name:	adapt. plates.png
Regards... da j-bro
Old 07-16-2012, 01:13 PM
Alfa.M.twd.2012
Cool
?? AnyOne ??
Regards... da j-bro
Old 07-16-2012, 03:45 PM
SPDSKTR SPDSKTR is offline
I'm a DlCK! So what?
Mein Auto: E46 ZHP TS2+ Coupe
Dynavin will suit most of your needs for media playback (USB, DVD, bluetooth streaming, etc.). As for speakers... beyond me.
EDIT: I missed the part about your factory navigation. I think Dynavin still works... I don't rightly know.
Sent from the Bamavarian Nexus.
Old 07-16-2012, 05:07 PM
crowz's Avatar
crowz crowz is offline
Mein Auto: '00 323i/97 528i/94 318is
Yep it works even if you have the factory nav, just requires a different install is all.
2006 325ci, coupe, stereo upgrade
