E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
Running Problem
Hey guys,
My car starts and turns on but then turns right off. Me and my dad just got done checking the voltage on the fuel injectors, changed the spark plugs and replaced the battery. I bought an ignition coil just haven't gone and picked it up yet. After removing a couple vacuum lines and taking out the fuel rail, we put everything back in as we took it out and the car just doesn't stay on. The fuel pump makes a funny sound when it used to run. It seems like the regulator just isn't keeping the pressure it needs for the gas to keep running the engine. We think it could be a vacuum line but don't know! Any help would be appreciated, thanks. |
i would go after the fuel pump
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming |
That's what we thought at first, but we took a hose off of the fuel regulator (my dad did and he's not the smartest man in the world) but gas gushed out everywhere so we know the fuel pressure is fine and fuel is pumping through..
"You gotta have a passion. If you wake up every morning doing what you love, you'll never work a day in your life." |
what year? you may have the 2 pump setup.
either that or a ground or theres a bad connection on the crank position sensor
I've got an 86, it does have the two pump set up I know that much
Try looking into it having a vacuum leak cause I have a bad leak in my e30 and it won't stay running
Does it just start then die?
Sure you didn't get the firing order off on the wires swap?
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
