E36 (1991 - 1999)
Old 07-17-2012, 11:49 AM
Joe__Sterling's Avatar
Joe__Sterling Joe__Sterling is offline
Fast Cars Suck!
Send a message via AIM to Joe__Sterling
Mein Auto: '13 FIAT 500 '68 BMW 1602
95 318i Intermittent start issues
so now that lola is my daily until i get new keys for the 5 series, this intermittent start issue is killing me. I have to pop start her more often than not.
Today i took the battery out, disassembled the ground, cleaned everything with baking soda and a toothbrush. Put it all back together and no bueno.
Turn the key and all of the lights come on as they are supposed to. Push my start button and the lights dim (except the millage which gets brighter) sounds like a solenoid clicks under the dash, and my radio goes off. No starter noises at all.
Apply a freshly charged jump pack and same thing. No indication of weak battery.
Now I take the battery from the Audi, which i know is good and plop it in the e36.
Fires up no problem.
drive the car to work, and shut it off and restart it several times. No issues.
Now before i left i placed the e36 battery in the Audi and that fired up just fine with it.
Also I drove the e36 yesterday so its not like it had been sitting.
any input guys? I'd like to not have to pull the starter due to lack of $ and it being a PITA. anything else I can eliminate first?
*The I Drove to Both East and West Coast Bimmerfest Club* Member #1
@Joe__Sterling on twitter & instagram (two underscores)
Old 07-17-2012, 12:52 PM
bmw-mania bmw-mania is offline
Mein Auto: BMW
solved your own problem..
Isolate the drain on your start button.
How old is your battery?
Old?
might be time for a new one.
You can buy the cheap ass battery..
Or you can replace your BMW battery with one from a MINI Cooper S..
Save some weight..
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 07-17-2012, 01:32 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
That Mini battery is down on CCAs compared to the OEM E36 battery, though.
1998 BMW 328is
1966 Pontiac GTO
Old 07-17-2012, 01:47 PM
Mein Auto: BMW
I thought we were talking 4 cylinder..
440CCA.. (?)
Should be fine for a 318i..
Would work for a 32Xi.. as long as charging system is green.
Old 07-17-2012, 01:50 PM
B_Rad_M3's Avatar
B_Rad_M3 B_Rad_M3 is offline
I6 feels good
Mein Auto: POS
That Mini Cooper Battery looks pretty cool... Never seen a white battery before...
Old 07-17-2012, 02:00 PM
Mein Auto: BMW
^ right?
I thought it was pretty cool too.. Leave it to zee germans..
Old 07-17-2012, 02:08 PM
Fast Cars Suck!
this isnt the first battery swap ive done to get her going. i did the same thing with my e30's battery and again withmy subaru's battery. so if the batterys are the issue then what could be killing them?
Old 07-17-2012, 02:12 PM
Mein Auto: BMW
You have a parasitic drain...
  1. At startup..
  2. Or all the time..
check your wiring to your push button...
Its a good place to start.
Its killing your battery.. "softly" as it were.
Or consider a few of these..
Old 07-18-2012, 07:27 AM
Time2Fly's Avatar
Time2Fly Time2Fly is offline
Sometimes Out To Lunch!!!
Mein Auto: 1993 318i 1994 325i 1998
Put a volt meter between the + cable and battery + terminal, with the key off you shouldn't hardly get any voltage draw I don't know what the SPEC is for that But I would guess about 1 to maybe 3 volts draw if your getting more than that start unplugging stuff until the voltage drops off. Remember unplug one thing at a time and then check the voltage. I will check the voltage draw on my 325 because it's stock nothing by a Sony CD player in it and get back with you. If all else fails you could put a battery cutoff switch in there. Stat thirsty my friend.......
