Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Forced Induction
Forced Induction
Aftermarket superchargers & turbos as well as tuning for stock BMW turbos (N54 motor - 135i / 335i / 535i). Force-fed discussion to make your car go faster
Old 07-17-2012, 08:17 PM
boostaddict21 boostaddict21 is offline
Mein Auto: 1987 BMW 325
new to bmw
so Ill be picking up a 87 325e pretty soon. I was just wondering if iit is a good engine to throw a turbo on. I believe the engine in it is the 2.7l inline 6
Old 07-17-2012, 09:37 PM
ProRail ProRail is offline
"Clunker" *****
Mein Auto: 1999 BMW 528A--165K
Not from what I've heaed. Did someone suggest this?
Old 07-17-2012, 09:42 PM
no, Ive just realized that ive been searching for the wrong engine. I was looking at the 2.5l m20 not the 2.7 m20. I found the most people use the head off the 325i and put on the block of the 325e.
Old 07-24-2012, 05:56 PM
"Clunker" *****
I stand by my original response.
Old 09-19-2012, 11:42 AM
damalex's Avatar
damalex damalex is offline
Mein Auto: 89 E30
You can do the head swap to a 325i (885) head but you will need wiring harness an ecu intake manifold an what not its easier to use a 325i then a 325e cause you will have everything already an youll only need just the bottom end out of a 325e but you can turbo a 325i as it is but you will only run low boost 8psi is what i think is safe the 2.7 head swap motor can take up to 15psi of boost cause the compression is lower you can look on e30tech.com for more info alot of them over there are running m20 boosted
Sent from my DROIDX using Bimmer App
Old 05-07-2013, 03:20 AM
ryan2805 ryan2805 is offline
Mein Auto: yes
Bmw is a best Car in the world and in this car many features which is very suitable for travelling
top ten classified website
