Z4 Roadster (E85) Front sidelight problem - help!! - Bimmerfest - BMW Forums
Old 07-18-2012, 12:17 PM
supernotts1862 supernotts1862 is offline
Mein Auto: z4 2.2i 2004
Hello all. I have a problem with my drivers side front side light. Only the drivers side doesn't work! I have checked the bulb and lamp connections, all was ok. When I tested the wire to the side light there was no power to the light at all! All other lights work fine! Any ideas????? Thanks
Sent from my GT-I9100 using Bimmer App
Old 07-19-2012, 01:26 AM
Bump!
Old 07-19-2012, 03:39 AM
STIHLBOLTS STIHLBOLTS is offline
Hat's On, Tops Down!
Mein Auto: 2013 335is
Did you check the fuse box to see if one was blown?
2013 335is Convertible
MODS:M3 Strut Brace / Smart Top Module / Ikon Lip and spoiler
VRSF Charge Pipe /
BMWCCA Member
Previous: 2004 3.0 Z / 2008 Z4M
Old 07-19-2012, 03:42 AM
Yes checked all of that. But If a fuse had blown then neither of the side lights would work. Only one doesn't work!
Old 07-19-2012, 04:13 AM
SC2003Z4 SC2003Z4 is offline
Mein Auto: '03 Z4 2.5i Silver/Black
If you are talking about the side marker...the one where the bulb sits in a long plastic pen looking like holder, then just play with same light on oposite side...I know you said you checked for power to that connection but I once had mine not work if I stuck it in and turned the holder too far. Since I knew the other one was good, I took it out and tried it on this side till I figured out where/when to stop when inserting it. If it is indeed this light, also try with a long skinny screw driver...it's a whole lot easier.
Javier 03 E85 2.5i
Old 07-19-2012, 04:18 AM
Thanks for that, I'll give it a go. I'm pretty sure I did take the other side out to check and that side works when the holder is taken out of the headlight. I'm wondering if it is a faulty holder and maybe the power cuts off to it when it fails and sends the power to the turn signal which stays lit constantly instead?!?
Old 07-19-2012, 10:31 AM
I've now run a wire from the left hand side light over to the right one and it works! The amber signal light still stays on constantly though! At least I now know there is no problem with the headlamp at all. Could it be the switch or a relay? I'm baffled!!!!!
Old 07-20-2012, 02:12 AM
Is there a relay for the side lights? Or could the switch be faulty??
Old 07-20-2012, 12:45 PM
Anyone have any ideas on this?
Old 09-18-2012, 01:18 PM
chase7 chase7 is offline
Mein Auto: Z3
Hi
I have the same problem on my z3 and it was a uncoupling diode under the fuse box in engine compartment,.
The system have two diode(about 1 in. white plastic) in wiring.On my z3 one have a wire comes out
Thank you
