E30 (1982 - 1993)
Old 09-01-2012, 04:19 PM
Jayboy85 Jayboy85 is offline
Mein Auto: 84 318i
Oil light flicker
I have an 84 318i and my oil light started Blinking. It only blinks when I'm stopped at a light or stop sign when it start driving it turns off. I recently changed the oil oil filter and air filter is also changed the oil pressure switch. Is this something major or a simple fix?
Old 09-03-2012, 06:05 PM
Joel86 Joel86 is offline
M3rKn
Mein Auto: 1986 BMW 325es
The manual says it is normal as long as the light turns off when you push the throttle. Same thing would happen to mine after an oil change. Can't say why.
Old 09-03-2012, 06:47 PM
Mein Auto: 84 318i
Cool thanks. I need to get a Damn manual. But I changed the oil again and put thicker oil and it hasn't came back on yet. So thanks for the help everyone
Old 09-03-2012, 09:43 PM
shima14 shima14 is offline
Mein Auto: 86 325e
With thicker oil fixing it sounds like it may be the bearing clearances...
Old 09-03-2012, 10:14 PM
Mein Auto: 84 318i
I take it back it still flickers when idling.
Old 09-04-2012, 08:30 PM
BMWFatherFigure's Avatar
Old School
Is the wire shorting out at idle? Pull the wire and tape it next to the connector (first one side then the other) for a day or so. If it still flickers it's a short problem - if not just engine or oil pump rebuild.
Old 09-04-2012, 08:38 PM
Mein Auto: 84 318i
I'm not really sure what you mean?
Old 09-05-2012, 12:14 AM
Old School
Pull off the sender wire. Tape it back on the sender but without malkng an electrical connection. The oil light will be off. If it still flickers when the engine is at idle then the wire is shorting to earth somewhere. You may have to try it on each side of the terminal to be sure. If that test does not bring the light on then you are in for a rebuild of either the oil pump, engine or both..
Old 09-05-2012, 12:22 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Or use a test pressure gauge
Then you know !
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 09-05-2012, 03:46 AM
Old School
Then you know !
If you have access to one. We kitted out guys must allow for others......
Old 09-05-2012, 04:12 AM
tim96 tim96 is offline
Mein Auto: bmw e30 320i
assuming it was not doing this before you changed the oil I would be checking you have the right oil filter and pressure switch. Maybe the brand of oil filter is not allowing enough flow? but should be fine if it is a main brand.
