Can I re-program TCM module to work on my car? - Bimmerfest - BMW Forums
Old 07-19-2012, 10:14 PM
ilian007 ilian007 is offline
Mein Auto: BMW 530i 2002
Question Can I re-program TCM module to work on my car?
Hi I bought used TCM module from ebay! It is absolutely same as mine. Bosch with all part numbers same as on mine. The only difference is the VIN number.
I tried to use it with my car. The car started, but transmission went to Safe Mode in 2 secs. It was still switching gears but very rough.
Any ideas?
Thank you
Old 04-17-2013, 02:46 PM
BeemVerg's Avatar
BeemVerg BeemVerg is offline
Officially Bimmerfested
Mein Auto: '01 530i
Did you resolve this issue ?
Pictured above: Smart Car circa 1955.
'01 530i, ///M Sports Package, Xenon lights, Steptronic A/T, icelinkPlus iPod module
'04 328i, Sports Package, Xenon lights, Dice iPod module
Old 04-17-2013, 02:51 PM
HTK12 HTK12 is offline
Mein Auto: E39 540i
It can be programmed, but are you sure the issue is with the module? Have you pulled the codes? How did you diagnose the issue is with the module?
Old 04-17-2013, 02:58 PM
kmorgan_260 kmorgan_260 is offline
Mein Auto: 1997 528i
This is interesting because I thought only the DME had to be reprogrammed. I am thinking about taking my 5 speed out of my e39 to use in another project and putting in an auto. I have not done much research but I was guessing it didn't involve any reprogramming. I replaced the auto tranny in my e36 a couple years ago with a used one and it worked fine with the existing TCM. In the course of troubleshooting the original tranny problem I swapped the TCM with one from another e36 and got no computer errors.
94 318I (Daughter's car), 96 740IL(current project), 97 528I(DD), 07 335I(Son's car)
Old 04-17-2013, 03:05 PM
Mein Auto: E39 540i
You need to reprogram when you do manual to auto or vice versa swap.
Old 04-17-2013, 03:20 PM
I thought when you go auto to manual you can take the TCM out altogether. Do you have to reprogram it to keep the DME happy?
Old 04-17-2013, 05:07 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Yes, the DME gets input from the TCM, and vice-versa.
Old 04-18-2013, 04:13 AM
Mein Auto: E39 540i
DME isin't the only one. Cluster and ABS should also be coded. Personally I would code the entire car. Makes future coding simpler.
Old 04-18-2013, 04:39 AM
diggyd357's Avatar
diggyd357 diggyd357 is offline
Mein Auto: 97 528I
I don't wanna sidetrack or hijack this thread, but I have a question... Is "recoding" something you can do yourself or do you need to bring it to a shop? My (old) indy said my TCM was not communicating.... I don't see how this is the case considering my shifting issue turned out to be a wheel speed sensor diagnosed right here on the fest and now it shifts fine (other than not wanting to shift outta first till car warms up)... Anyway, if I were to find a matching TCM and wanted to swap it out could I do the reprogramming at home??
Sent from my SPH-L710 using Bimmer App
Old 04-18-2013, 05:59 AM
Mein Auto: E39 540i
Yes you can. You'll need a cable and a laptop to do it. If your interested you can find the information in the VERY best of E39 Links. Just search for NCS Expert and you'll find the information about the cable, software etc.
