E34 (1989 - 1995)
Old 07-20-2012, 09:56 AM
magusat999 magusat999 is offline
Mein Auto: 1994 BMW 525i
What is this hose for?
Someone posted this really good pic of the front of an e34 engine, and hopefully it will help me identify a bad leak I've been having coming from this area (and is not the thermostat housing or the radiator hoses). I circled in red this small hose - can someone identify it for me? I think this hose is chopped in my car (someone was working on it before I purchased it).
I'm guessing the top of that hose connects in this are? Would that be correct?
Freaking leak is my white whale... If that hose doesn't carry coolant - can someone tell me what else in this area besides the tstat housing and radiator hose could be leaking (its above the waterpump)? Thanks.
Old 07-20-2012, 09:58 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
That is not a hose. That is the crankshaft position sensor. it is a wire. If it is not intact, the engine will not run. If you are loosing coolant, you need to look closer to find it. Good luck. Remember, don't let the car overheat!
Steve
Calypso Red 1992 525i with 170K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 07-20-2012, 10:27 AM
Well thanks - that must not be it, then.
Old 07-20-2012, 10:52 AM
goosefoot33's Avatar
goosefoot33 goosefoot33 is offline
Manualaholic
Mein Auto: 01 330Ci/94 530i
If its not the water pump, my bet is on the thermostat housing. That is a quick and painless fix.
Sent from my Droid Incredible
Full 1995 530i Part-out! http://www.bimmerfest.com/forums/sho...d.php?t=568506
BMWCCA Member# 451235
(Summer) 2001 330Ci - ZSP
(Winter) 1994 530i "Greenie" - LOADED
e34, hose, leak, repair
