Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 07-20-2012, 02:33 PM
beemer1804 beemer1804 is online now
WAR MACHINE
Send a message via AIM to beemer1804 Send a message via Yahoo to beemer1804
Mein Auto: 95 740IL
Question 95 740iL - Noisy
When i start my 95 bmw 740il the car starts but the pulleys are squeaking and it sounds like it needs to be lubed or something but i dont know if i should wd-40 it or get new pulleys, how should i fix this problem and save money doing it?
Old 07-20-2012, 02:37 PM
WAR MACHINE
Mein Auto: 95 740IL
Question Noisy
Old 07-20-2012, 02:51 PM
alpinaman24's Avatar
alpinaman24 alpinaman24 is offline
what amg?
Mein Auto: 07 B7,91 735i , 91e30sold
if the squeking goes away you eighter need a new belt
or
a tensioner
or
a roller ..
goodluck
Old 08-01-2012, 06:54 AM
WAR MACHINE
Mein Auto: 95 740IL
Question
so i should wd-40 the pulleys and what about the fan it looks and sound like it needs some lube also, what do you think?
Old 08-01-2012, 01:12 PM
what amg?
no
you should first take the belt off and see which tensioner or pulley is making noise ..
then you replace it or them
get a new belt
install and noise should go away
LUBE will NOT fix your problem
Old 08-01-2012, 01:19 PM
WAR MACHINE
Mein Auto: 95 740IL
For me to do that would i need a special tool or something of the sorts?
Sent from my ADR6400L using Bimmer App
Old 08-10-2012, 05:31 AM
BMWFatherFigure's Avatar
Old School
Old belts get a glaze on them. The glaze squeaks. Bearings make a different noise. Spray some water at the belts while its running. If noise reduces or goes away change the belts!
HTML code is Off
