Old 07-20-2012, 08:14 PM
Vortec4800 Vortec4800 is offline
Mein Auto: 13 X3 35i MSport, 09 135i
Mirror Folding?
I see people talking about an option to fold the mirrors when you lock/unlock the vehicle but I haven't seen that option in any of the cheat sheets. Can someone point me to the required modules and options to enable this via fob and CA?
Old 07-20-2012, 11:06 PM
April1 April1 is offline
Mein Auto: X3 2011
Mirror closing is a delayed action and happens when close key is held down for few seconds. This is set in CAS module.
Old 07-21-2012, 12:00 AM
Isn't that window closing?
Old 07-21-2012, 06:07 AM
gspannu gspannu is offline
Mein Auto: 5 Series F10 2012 Model
Its for both Window Closing & Mirror fold - both happen after a long hold of the close button.
Old 07-21-2012, 09:34 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
Mein Auto: 2011 535i M-Sport
Straight from the F10 & F25 & Cheat Sheets:
KOMFORTSCHLIESSUNG_FB = Closes mirrors + windows + moon roof through Key Fob
KOMFORTSCHLIESSUNG_PA = Closes mirrors + windows + moon roof through Comfort Access
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 07-21-2012, 11:32 AM
Ah, I see. Our old GLK could be programmed so the mirrors would fold/unfold after a single press of the lock/unlock and I was expecting something similar, which is why I was confused.
Thanks for the info everyone.
Old 07-21-2012, 11:42 AM
Mein Auto: X3 2011
I prefer the way BMW has implemented as I dont want mirrors to move every time I press lock/ unlock buttons.
Old 07-29-2012, 10:27 PM
mauipascal mauipascal is offline
Mein Auto: 740i
you can also do that using ncs expert and than car memory, there it is very easy to set.
Old 12-22-2012, 10:24 AM
Travel4Surf's Avatar
Travel4Surf Travel4Surf is offline
Mein Auto: Everglades 243
My windows roll up but the mirrors don't move. F10 2013 with folding mirrors.
Any ideas?
Old 12-22-2012, 10:27 AM
Any ideas?
Besides these two:
CAS / KOMFORTSCHLIESSUNG_FB = aktiv
CAS / KOMFORTSCHLIESSUNG_PA = aktiv
You also need to code this one:
FRM / ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN = aktiv
Did you code all three?
- BMWCCA #446923
- flick
Old 12-22-2012, 10:31 AM
Thanks for the quick response, the FRM make it work!
Old 12-22-2012, 10:32 AM
- BMWCCA #446923
- flick
Old 12-28-2012, 01:56 AM
snowcatxx87 snowcatxx87 is offline
Mein Auto: F01
There have been many cheat sheets showing mirrors in the CAS - in my f01 it's in the FRM (for the e coders - Gm5)
Old 12-31-2012, 02:30 AM
stormace stormace is offline
Mein Auto: f01, fx35, f10
On the mirrors not folding, I coded all 3 aktiv, but weird thing is the aktiv value is always paired with werte=00 rather than 01. If I code it with 01, it always goes back to nicht_aktiv. These are on the cas module. te frm is as what the cheatsheet says. Hence, my mirrors still don't fold but windows roll up with comfort access and key fob. Any ideas?
ED on 3.30.07 |'07 335i coupe|BlackSapphire|CoralRed|Nav|Comfort|Sports|Pr emium
Redelivered, Reunited! 5.24.07
2013 F10 535i|TiAg|BlackDakota||Tech|MSport|Premium|Multi Contour|Hifi|Rearview Camera|PDC
Old 12-31-2012, 05:15 AM
Do not get caught up on the Werte Values, as they differ on some Chassis. In general, always change only the dropdown box, from aktiv to nicht aktiv or vice versa, and let it change the Werte Value for you. In general, the Werte values themselves when they represent a state, such as on / off should not be directly edited. It is only when the Werte Value represents an actual value such as voltage, time, etc. that you directly edit it.
Go back and set everything to its default values, then change only the dropdown box, and then FDL Code it.
- BMWCCA #446923
- flick
Old 12-31-2012, 08:06 AM
Did so, got it. Cheatsheet should be updated to werte=00 on this for all three modules for this.
Old 12-31-2012, 08:13 AM
First of all, your welcome.
I guess you missed my point where I said it differs by chassis. If it is updated to reflect your chassis, then it will be wrong for other chassis'.
On my new unreleased Cheat Sheet version 4, to eliminate this confusion, I have only one column showing either the driopdown box value or the Werte Value, but not both.
- BMWCCA #446923
- flick
Old 12-31-2012, 10:50 AM
FYI. I can't answer your PM:
stormace has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
- BMWCCA #446923
- flick
Old 02-23-2013, 01:43 PM
spadae2 spadae2 is offline
Mein Auto: 2013 550i xDrive
Hello,
Just changed the delay values to ZERO. Does not work, they fold first before the windows? I thought I read where people like me in the cold.... did not want the mirrors to close because of freezing in the winter. There is a video on youtube that shows then not folding?
TX,
ER
2013 550i X-DRIVE, M-sport, Imperial Blue, Black Nappa, DHP, B&O Sound, DINAN stage 2, M5 Grille, Escort 9500ci, Coded.
Old 02-23-2013, 02:19 PM
FrogmanF30's Avatar
FrogmanF30 FrogmanF30 is offline
Mein Auto: 2012 328i
Yeah, they are supposed to fold before the windows go up or down.
I'm used to only coding F30's, yours may be different.
Old 02-24-2013, 11:43 AM
octopump's Avatar
octopump octopump is online now
Brevity = soul of wit
Mein Auto: F10
Originally Posted by shawnsheridan View Post
Besides these two:
When done those three:
CAS->3003 FH MASTER->KMFRT_SCHLIESSEN->Werte=00
(the default value is Werte=0F)
if you want no delay when locking the car with the FOB or comfort access.
Old 02-24-2013, 02:08 PM
Thanks I have done that, but I do not want the mirrors to fold in. What can I change to stop them.
Old 02-24-2013, 11:09 PM
razorback razorback is offline
Mein Auto: GT 530d
well, you would have to set
FRM / ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN = nicht aktiv
BMW GT 530d (MY 2013)
Old 02-25-2013, 01:58 PM
Ok, I thought that needed to be activ for the others to work. Tx
Old 03-06-2013, 11:44 PM
dleong dleong is offline
Mein Auto: F10 528i
Thanks octopump for providing the program setting for no delay. Now I can just lock the car & have the mirrors close witnout having to press on the FOB or door handle for more than 2sec. And this is my first attempt at coding too.
Cheers!
