BMW 320 2007 Model - Red Cog, Exclamation Mark. - Bimmerfest - BMW Forums
Old 07-22-2012, 06:16 AM
sticktoplans sticktoplans is offline
Mein Auto: BMW 320 E90
Exclamation BMW 320 2007 Model - Red Cog, Exclamation Mark.
Hi,
Bear with me as I detail my escapades because I really need your experience with these issues and want to provide relevant details.
I have a 2007 BMW 320 (E90, isn't it?). Mileage: ~96K Miles (155K Kilometeres)
I have just got out of an official BMW CS center (mechanic) with the diagnosis of a bad transmission system - which means it's gone. The price tag: $8,000 for a refurbished, around $13,000 for a new one. (I'm not here to complain about the price, these are only above average prices here in Israel)
All they did was plug my car for 20 minutes to the computer, they did not check any transmission system fluids/oil. Their diagnosis was very fast - "it needs replacement".
What I experience is this:
only in SOME instances, when the red transmission error ISN'T showing up, the car may have trouble accelerating from stand still. After it accelerates, there are no troubles whatsoever. This does NOT happen every ride.
In some (relatively rare) instances, especially after long rides, the red cog symbol with an exclamation mark inside it (transmission error) shows up, and then the car really has problem moving, and it seems like it's "locked" in some gear other than 1/2, which makes it really sluggish.
As I said, until this icon appears, the problem is relatively minor.
I have tried Googling this problem in Hebrew to find similar problems, and found one exact case like mine where the official BMW dealership says it's a faulty trans. system, and the problem is solved simply by changing the trans. system fluids oil or another, much cheaper solution. It seems that the dealerships are quick to make assumptions without really checking, they just "follow the computer".
However, I don't want your opinions to be biased, so please advise from your own knowledge/experience, on what to check before I have to spend 50% of the car's worth on a new trans. system.
Old 07-22-2012, 08:06 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Originally Posted by sticktoplans View Post
....official BMW dealership says it's a faulty trans. system, and the problem is solved simply by changing the trans. system fluids oil or another, much cheaper solution. It seems that the dealerships are quick to make assumptions without really checking, they just "follow the computer".
BMW dealers do no repair on transmissions other than R&R - small wonder, diagnosis.
The $ charge: How's it break down, labor/part/core charge?
Old 07-22-2012, 08:25 AM
Hi, thanks for very much for replying. I don't really get the technical term R&R, and what does "small wonder, diagnosis" mean? As I said I'm not American so sometimes I find it hard getting humor/pun.
The $ charge: I didn't even care to ask. I told them to discharge the car immediately, but not before insisting they sign their diagnosis.
After more research, I think I'm going for:
1) Software Update and speed output/input sensors, if fails;
2) replace ATF and/or battery
If none of these work, I'll simply let that damn car sit there. I'm not going to fix it for 50% of it's market price.
Old 07-22-2012, 08:51 AM
R&R -- Remove and replace
Small wonder, diagnosis -- given BMW does no transmission repair, not surprising they'd recommend replacement instead of looking into the problem and fixing what's wrong.
Could be as simple as a $100 valve.
Old 07-22-2012, 09:10 AM
Yeah, that's what I guessed but didn't want to take a chance, thanks!
It could still be the Red Cog of Death, right..?
