Old 07-22-2012, 09:54 AM
Sonny Latona Sonny Latona is offline
Mein Auto: 1988 635 CSI BMW
95 740iL - Oil Light
The "stop engine check oil "light in my 1995 740il goes on when car is running at idle and when I slow down to stop and or traffic lights while driving,what could this mean?
Old 07-23-2012, 07:50 PM
Koolkidd89 Koolkidd89 is offline
Send a message via AIM to Koolkidd89
Mein Auto: 1997 BMW 740IL
I had the same issue 3 months ago with my E38 '97. "Stop eng oil press" is the msg shown. I went got a full synthetic oil change after buying the oil and filter (the labor cost $20) and I stopped seeing the warning. 2 months go by and upon stoppin abruptly for a cat that decided he wanted to TRY to use one of his 9 lives, I got the msg again. I found out that I have an oil leak and more specifically, I need to change my valve cover gaskets. Your issue may not be as serious, but I'd definitely look into th possibility. More or less, get the oil changed or change it yourself, if yu receive the error again in 2 or more months, then you have an oil leak
Sent from my SPH-D700 using Bimmer App
Old 07-26-2012, 03:25 PM
Thanks.... mechanic mentioned trying to use a heavier weight oil,will definitely look into possible oil leak....
Old 07-27-2012, 02:52 PM
OUR valve cover gaskets are known for leaking oil, also note that yu probably won't notice oil spots on the ground unless its really really badly leaking. I have to replace mine as wel as my valley pan gasket (leaking coolant).
Sent from my Samsung Galaxy S using Bimmer App
Old 07-28-2012, 07:46 AM
joyism5's Avatar
joyism5 joyism5 is offline
Mein Auto: '99 740IL, K75RT
If you have an oil warning light but oil level is ok when you check the dipstick, you could have:
-oil pump sump is clogged (you need to remove lower oil pan to inspect/clean)
-oil level sensor is faulty (there is a TSB out there about that) and you get false warnings.
This issue should be sorted ASAP because if you fall into the first scenario, irreversible damage to the engine is occurring. In this case the oil warning is accompanied by a dry running sound of the top of the engine.
Heavier oil, I don't understand...how will stop the oil light.
JOY = BMW
HTML code is Off
