The X5 SAV Forum
Old 09-12-2016, 01:12 PM
2005 X5 3.0i 2005 X5 3.0i is offline
Mein Auto: 2005 BMW X5 3.0i
2005 BMW X5 3.0i - Transfer Case Actuator Motor Issue
I have a 2005 BMW X5 3.0i and I was getting the orange 4x4 and orange brake light only. I changed the inside plastic gear. It stayed off for a few days then when I went on the freeway the same 2 lights came back on. I noticed that when I had it apart the worm drive was wobbly in the motor. I read something about a sensor and wondered if that was the problem. The old gear wasn't worn.
Old 09-12-2016, 02:39 PM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Welcome to Bimmerfest! I've moved your question to our X5 forum, you'll get more help in here.
Tim
Old 09-13-2016, 06:07 PM
Fifty150hs Fifty150hs is offline
Mein Auto: SF Bay Area
You need to have the codes read. Most likely it will tell you what your problem is and prevent you from just throwing parts at it. Your lights can indicate a variety of problems that you won't be able to decipher without the codes.
Old 09-15-2016, 12:58 AM
Thanks I will do that. I will repost what I find out.
Old 10-26-2016, 08:29 PM
Vicster Vicster is offline
Mein Auto: X5 4.4i
What did you find out about this?
