X3 E83 (2004 - 2010)
Talk about the E83 BMW X3 in this forum! |
I need some help. My 2008 X3 with only 45000 miles just had to have it's main EWS computer replaced. This was due to the car not starting. After replacing this and the starter and paying for 3 hours of diagnostic time.....the car still will not start. Now the dealer wants two more hours of diagnostic. I am starting to feel that they do not know what they are doing. I find this is very upsetting for such a high quality vehicle to not work considering the low mileage and young age. Any thoughts?
What is the EWS?
If this isnt under warranty ask it to be covered under the "Goodwill" TSB. At 45,000 miles and an 08 it is close enough where the right dealer will help you out. If they won't call corporate to get an approval go to another dealer and explain the situation and ask if they will. They may even let you buy the extended warranty still to cover it longer. Remind them that you are thinking about doing just that. Good Luck
2013 S4 Loaded (and NO RFT's) Awesome is an understatement 2008 MT X3 2007 AT X3 RIPOS ![]() 2005 GC 2000 Jeep Cherokee 1997 Twin Turbo RX-7 1984 GTI Wolfsburg Edition Neuspeed and more |
The computer module for the immobilizer. Does all the ignition key authorization business.
Electronic Watchdog System or something. It communicates with the main vehicle brain - the DME/ECU/ECM. |
I have never heard of this...what does it mean? I will certainly try and thank you so much for the suggestion!
The EWS is a module that is under the driver's side dash. It stores a series of codes that are downloaded into the key when the car is turned off. That code is then used to determine that the key is "legal". If it isn't, the fuel pump & starter will not work.
Could you be a little more specific with your symptoms? The classic EWS problem is that when you put the key in and turn it to the run position, everything seems to be fine, but when you try turning the key to the start position, nothing happens. By nothing, I mean there is no "Click" from the solenoid and now sound from the starter. It is very disappointing that the dealer would try changing the starter first. It is a lot less labor to replace the EWS & realign it with the DME. (the main engine computer) Just be aware that to get a new EWS, you have to furnish your VIN number & the dealer has to order a new one because your unique set of 200 code numbers needs to be programmed into the module. |
Find another dealer. Even if they are farther. They arent even trying and you should file a complaint with BMWNA.
Do a search function under the word goodwill. This is a technical service bulletin that allows a dealer to appeal to BMWNA on your behalf to cover or reduce costs on vehicles just barely out of warranty extending it to 60k miles and time. So three things: Find another dealer. Explain what you have been through, including the attitude. Find goodwill tsb on bimmerfest and read it to service manager at other dealer and appeal to their better nature. Be really nice. Last, write a letter condemning the one dealer, and compliment the other. I had one dealer put me through hell for five months and another dealer solve the problem in less than 5 hours. No kidding. Again good luck.
Well our drama has gotten worse. We went to BMW corporate and they said there is no Goodwill program. What is worse the person we spoke to there said he would see what could be done and get back to us. After three days of dodging our call another person finally responded that there was nothing that could or would be done. I love my car but now have a great dislike for BMW. We thought we were buying a premium quality vehicle. I traded my Mercedes for this car.......never should have done that. When I bought my Mercedes I bought the extended warranty but never used it......ever........ so I thought why would I need it with a BMW. I will now be unloading my BMW as I can not take the chance of this happening again.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
