Old 01-16-2013, 06:54 AM
M6Power M6Power is offline
Mein Auto: BMW 645CI
Unhappy Radio faillure
:Hi All,
The radio goes out for a split second on my 6 series, and then it comes right back on. It looks like I'm losing current on my car, but only for a split second.
Anyone has experienced this problem or knows what it may be the cause of it?
Thanks in advance,
Old 01-16-2013, 07:00 AM
645/333's Avatar
645/333 645/333 is offline
Michael
I had this it sound of pops goes off then comes back on, I did an Idrive reset which helped but never got to the bottom of it, but it was so rare I just ignored or tried to work out if it was in conjunction with something else switching on!!
Old 01-16-2013, 07:32 AM
Thanks, How you do an IDRIVE reset
Old 01-16-2013, 07:44 AM
JDPSP JDPSP is offline
Mein Auto: 2005 BMW 645ci
hit volume the CD eject and Nav DVD eject buttons all at once
JD
Old 01-21-2013, 09:27 AM
DrDubai DrDubai is offline
Mein Auto: 650i Convertable
Tried this many times, did not resolve the problem. Does the same when i am in the phone. Any other solutions? Also, how do i switch the passenger airbag dash light off?
Old 01-21-2013, 09:44 AM
It sounds like the CCC, if a 645 model, needs to be replaced and then coded in.
Old 01-21-2013, 11:09 AM
Thanks. What is ccc? Its a 650 convertible 2006 american spec and code in dubai. How much will this cost?
Old 01-21-2013, 02:04 PM
roseng's Avatar
roseng roseng is online now
Mein Auto: 2016 528i + 2007 650 Vert
CCC is the Car Communications Computer. It's the same on 645/650 till '09 when the new CIC was released.
You need a BMW specialist to determine what modules/section needs to be replaced.
Most modules require programing so the car recognizes it.
07' E64/Black....14' F10/M-Sport White
Old 01-21-2013, 02:09 PM
On a 2006, you have a CID - this is the computer that controls all of the iDrive functions. Here is a BMW factory parts company listing for original equipment http://www.getbmwparts.com/parts/200...w=11&maxRow=10 After you install - Then take the car over to your shop and let them code the new unit. Make sure that they have the optical interface / without it, they can not code. It's about 1.5 hours - the install is 20 minutes but remove your DVD and CD first ... if you can.
Old 01-21-2013, 04:53 PM
blakedanatural blakedanatural is offline
Mein Auto: 2005 645 ci convertible
Had my CCC replaced last month. I had similar issues with my dash going blank.
Blake
Old 01-21-2013, 06:29 PM
HerbP HerbP is online now
If the Nav system & the Radio do this early every morning, I would say you have a bad or weak battery. I saw mine do this for months before I changed the battery. After changing the battery, I have not seen it happen since! I would never suspect a bad battery to do this, but this is a BMW!
Old 01-24-2013, 03:02 PM
Angry
I had the battery replaced last year, but I know that the 6 ers are very tough on batteries. Now every time i loose the radio sound the dynamic drive control warning comes on. driving me nuts.
Old 01-24-2013, 03:05 PM
Never had an issue with the battery. Did you go with BMW battery? When was the last time you had the software updated?
