Old 07-25-2012, 10:04 AM
digimurda digimurda is offline
Mein Auto: 740i
will i lose my actual mileage if a change the ins. cluster??
hi,
i have a 05' 545i
something is wrong with 2 of my gages, so im thinking about picking
up a whole instrument cluster at a junkyard,
my question is will i lose my actual mileage???
thanks...
Old 07-25-2012, 10:36 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
Originally Posted by digimurda View Post
hi,
i have a 05' 545i
thanks...
It won't work, the new cluster has to be programmed.
Dealer would not program used cluster.
Old 07-25-2012, 11:00 AM
Mein Auto: 740i
so ill end up with the mileage on the old cluster?
Old 07-25-2012, 11:01 AM
Mein Auto: 740i
i meant with the mileage from the donor car i get the used cluster from?
Old 07-25-2012, 02:05 PM
borderchris's Avatar
borderchris borderchris is offline
Was ist los? Der Hund!
Mein Auto: 335i E92
2007 E92 335i . Space Grey . Premium . Sport
2006 E85 M Roadster . Alpine White . 6MT
2006 E60 550i . Sapphire Black . A5 . Sport . Premium
2003 E39 530i . Titanium Grey . 5MT . Sport . Premium
1989 E34 535i . Black . A4 . Premium . RIP
1981 E28 530 . Grey . A4 . German Specs . RIP '94 in USAREUR
1977 E21 320 . Light Blue . 4MT . German Specs . RIP '92 in USAREUR
Old 07-25-2012, 02:11 PM
Mein Auto: 335i E92
Sketchy question, my friend.
It's more complex than that; the new cluster must be programmed by a BMW system to be recognized by your car; during that time the milage will be set. If you have portions of the cluster that arn't working, I caution you- It may not be the cluster, since everything is software based. Have it looked at if you're not that familiar with it. That said, I've never seen a cluster with "parts" of it not working, except for the digital center. The gauges are simple, and depend on their sending units.
How do you know that the cluster in the donor car has lower milage? Just sayin...
Old 07-25-2012, 02:26 PM
Mein Auto: 740i
so i cant just put a used one right on?
Old 07-25-2012, 05:01 PM
etnav382 etnav382 is offline
Mein Auto: 06 550i
You can put in a used one and you will just have a dot after your mileage stating that the cluster mileage doesnt match whats in the key, engine computer and wherever else they store mileage. I know because I have an M5 cluster that I test fitted to my 550 and other than the transmission and electronic damper faults everything worked fine. The only reason I got those faults were the cluster was programmed for SMG and I have steptronic. The second I put the car in first manually the trans fault disappared. Moral of the story get a cluster that was from a car that has the same tranny as you and you'll be good. Otherwise anybody that knows how to code can fix that for you. Also go over to 5series.net and search for the people that did the M5 cluster retrofit, they might tell you slightly more that what I have and the correct coding process since dealers wont do it.
Old 07-25-2012, 09:53 PM
Mein Auto: 06 550i
Sorry double post.
Old 07-28-2012, 12:34 AM
2chill's Avatar
2chill 2chill is offline
Mein Auto: 2008 528XI
Let's start off from the beginning. Which two gauges are giving you trouble and what are they doing or not doing? I suspect the problem is not the cluster.
PP, CWP, NAV, satelite radio, USB, Folding Rear Seats.
