Old 07-25-2012, 10:03 AM
Freewheeler Freewheeler is offline
Mein Auto: 2012 X5 35d
AC in Center Console Problem
It seems in my '12 X5d the duct under the center console must be disconnected or missing altogether. When the rear AC is on, cold air pours out of every joint in the center console, so my hot coffee turns to iced coffee and the storage bin becomes a refrigerator. God forbid I turn the AC off because everything in the bin gets soaked with condensed water. I'm not exaggerating.
I commute every day in this and would rather not leave it at the dealer if it's something I can do myself. Assuming the duct is there but disconnected, any knowledge on if something can be done without pulling the whole center console out?
Old 07-31-2012, 09:37 AM
[Resolved] AC in Center Cosole Problem
As it turns out, this was operator error highlighting a design quirk revealing a design/engineering/production flaw.
Operator Error: A rear passenger turned off the rear seat vents by closing them but leaving the fan on high.
Design Quirk: There doesn't really need to be vent cutoffs except when one rear passenger wants air and the other not, so the quirk is that you can have the fan on high but close the vents.
Design/Engineering/Production Flaw: This caused air to leak out of the duct connections somewhere, pressurizing the whole center console which leaked through all the openings in the center console.
Once I opened the rear vents the air stopped leaking which resolved the problem. Seems this should have been looked at more closely by BMW, or maybe mine just has bad duct connections.
ac, bin, console, duct
