Old 07-25-2012, 10:51 PM
bmw2qnj2le bmw2qnj2le is offline
BMW740i
Mein Auto: 740i
2001 740i - PS fluid connects with trans. fluid?
2001 740i -
1. Is it true that the power steering fluid and transmission fluid are connected together in the same black reservoir on the driver side? I trace the hoses: 1 go to the power steering pump; the other goes to the cooling fins in the front then back to the transmission. That is my thought. Many thanks in advance
2. . 2 weeks ago, my NAV display stopped working after I disconnected the battery to replace my oil cover gasket. Where can I find the fuse box? What exact fuse that I look for?
Many thanks in advance.
Old 07-26-2012, 07:01 AM
joyism5's Avatar
joyism5 joyism5 is offline
Mein Auto: '99 740IL, K75RT
Originally Posted by bmw2qnj2le View Post
2001 740i -
No. Transmission fluid is a separate system. There is a transmission fluid cooler but they never mix. The only way to check level is to jack the car on 4 stands and remove the filling plug. Check E38.org or search forum for threads.
JOY = BMW
HTML code is Off
