E34 (1989 - 1995)
ABS Sensor? No trans shift. Please help!
Hi guys so this weekend I changed my valve gasket and you know you have to unplug all these wires right? Well I also did one of the front shocks and I disconnected the ABS wire, I think, So now everything is back together and did a test drive. Now my transmission won't shift out of first gear. Will only **** on manual. I also have the traction control light on. What may it be?
***shift
did anybody answer this, or did you ever resolve the problem?
yes i dis fix it
info I used: Double check the connections on all of the wiring you took off (you did remove the intake manifold, right?) - I'm betting you put the connector for the TPS in the wrong place. I'm thinking the car doesn't know the throttle position and is possibly reading it as WOT, so it's shifting late. Check that first, and I'll think on this some more while other people look in here to see what's going on.
I'm showing a transmission code 700 . Any ideas
I actually don't have any idea on that, sorry. Maybe someone else knows?
I found this but its for engine code which is different , might not help, might not. Good luck, if you find a fix update us ![]() http://www.bmwe34.net/E34main/Trouble/Engine_codes.htm |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
