Old 11-16-2012, 10:40 AM
gumes gumes is offline
Mein Auto: E90 LCI 318d 10/2010
I have a Internet option now, but gives the error 'Not available for your country'
Old 11-16-2012, 10:42 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
Mein Auto: 2011 535i M-Sport
That usually indicates you either did not "update services" though the iDrive menu, or there is an issue with the VIN you are using. Did you read the VIN back from the Combox and confirm it is the donor VIN?
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 11-16-2012, 01:09 PM
doctom doctom is offline
Mein Auto: 2012 528i
I think that in Europe Internet works only in UK, Germany and maybe Austria. I bought my 528i in UK and it worked while I was in UK and in Germany, but when I came back to Croatia, where I live, I got the same "Not available..." message
If you were buying the car from authorized dealer in Poland, you probably couldn't buy this option because it's not supported in Poland.
It's not the problem with VIN, I think, but with the fact that BMW does not support internet in every European country.
Old 11-16-2012, 01:35 PM
Yes I read the vin from the Combox and it is ok. I think the problem is with my phone. I have Galaxy Ace and I don't have tethering via bluetooth
Old 11-16-2012, 02:59 PM
I think you are confusing 614 Internet via the car's SIM Card and Data Connection versus Internet via a mobile phone SIM Card and data Connection using Bluetooth Tethering. With the latter, you are not actively using BMW Portal Servers, and it does not even know what country your car is physically in. It uses the Donor VIN only when services are updated via the iDrive to sync your car services with your current active BMW Assist account options.
- BMWCCA #446923
- flick
Old 11-17-2012, 12:20 AM
You are probably right. I missed the original post from Gumes
Old 11-17-2012, 08:28 AM
I did everything that was needed, but the internet further displays a message "Internet is not available in your country" When I update the services it downloads 5 kb of data and nothing has changed. VIN of the donor's ok.
Here is ma trace files:
mcic
Code:
TYP_LENKUNG
	linkslenker
SPRACHE
	englisch
	koreanisch
	china_trad
	russisch
BT_UFN
	wert_01
USED_MICROPHONES
	wert_01
PHONE_TYPE_JAPAN
	nicht_aktiv
RINGTONE
	ringtone_1
RSE_HIGH
	nicht_aktiv
TDA_CFG_CUST_MOBILE_USE_M
	aktiv
TDA_DEACTIVATE_STATUS_M
	nicht_aktiv
BT_OBJECT_PUSH
	nicht_aktiv
MICROPHONE_SENSITIVITY
	l4_mic
PB_DOWNLOAD_PRIORITY
	wert_03
INBAND_RINGING
	nicht_aktiv
CONFIG_INDEX
	config_index_3
DPAS_INDEX
	dpas_3
TESTCALL_FLAG_ENABLE
	nicht_aktiv
A2DP_AVRCP_EIN_AUS
	aktiv
AKD_SUPPORTED_POIS
	wert_25
API_EIN_AUS_MED
	nicht_aktiv
API_IPOD_ONE_WIRE
	aktiv
API_IPOD_TWO_WIRE_SERIEL
	aktiv
API_TWO_USB_M
	nicht_aktiv
AUDIO_NOTES_EIN_AUS
	nicht_aktiv
AUDIO_SOURCE_FILE
	file_1
AUDIO_VERSTAERKER
	wert_01
AVRCP_BROWSING_EIN_AUS
	nicht_aktiv
CALENDAR_EIN_AUS
	aktiv
CAR_TYPE_IPOD_LOGO
	bmw
CONTACT_NUMBERS_BCALL_M
	nicht_aktiv
CONTACT_NUMBERS_DEALER_M
	nicht_aktiv
CONTACT_NUMBERS_HOTLINE_M
	nicht_aktiv
CONTACTS_EIN_AUS
	aktiv
DATACOMM_CSIM
	aktiv
DATACOMM_INTERFACE
	mamac
DRM_CHIP_ENABLED
	aktiv
DUN_PROFILE_M
	aktiv
EMAIL_EIN_AUS
	nicht_aktiv
EXTERNAL_CALL_LISTS_M
	aktiv
FBLOCK_PHONEBOOK_EIN_AUS
	nicht_aktiv
GPS_FROM_MOST
	nicht_aktiv
GPS_POSITION_TIMEOUT
	wert_01
HEAD_BOOT_UP_TIMEOUT
	wert_15
HEAD_UNIT_MODEL
	cic_mid_rueko
HEATING_CONTROL_ENABLED
	aktiv
HORN_CONTROL_ENABLED
	nicht_aktiv
INCOMING_CALL_LIST_M
	aktiv
IP_ROUTER
	aktiv
LIGHT_CONTROL_ENABLED
	nicht_aktiv
M_SECURITY_MODE_AEH
	des_cbc
M_SECURITY_MODE_AEP
	aes_128
M_SECURITY_MODE_ASH
	des_cbc_mac
M_SECURITY_MODE_ASP
	hmac_sha_256
MAIN_BOARD_ALONE
	ecallboard_present
MED_SVS_EIN_AUS
	nicht_aktiv
MMS_EIN_AUS
	nicht_aktiv
MULTI_PARTY_CALL_M
	aktiv
MY_INFO_SUPPORTED_POIS
	wert_25
ONLINE_ROUTER
	aktiv
PHONEBOOK_NAME_DISP_ORD_M
	last_first
PICTURE_VIEWER_EIN_AUS
	aktiv
PIM_BILDER_EIN_AUS
	aktiv
POWER_FOLLOW_UP_THRESHOLD
	wert_01
RDL_CONTROL
	aktiv
RDU_CONTROL_ENABLED
	aktiv
REMINDER_EIN_AUS
	aktiv
REMINDER_TRIGGERS_EIN_AUS
	aktiv
RESPONSE_ON_HOLD_M
	nicht_aktiv
SECURE_SIMPLE_PAIRING_M
	nicht_aktiv
SIM_ENABLED_MB
	csim
SMS_EIN_AUS_MED
	aktiv
SORTING_VARIANT_M
	standard
STARTUP_ACTIVE
	nicht_aktiv
SVR_ENABLED
	aktiv
SWUP_ASK_CONF_ENABLED
	aktiv
SWUP_ENABLE_ENG_UPDATES
	nicht_aktiv
SWUP_ENABLE_SW_UPDATES
	nicht_aktiv
SWUP_SOURCE_ONLINE
	nicht_aktiv
SWUP_SOURCE_USBMSCDD
	nicht_aktiv
TASK_EIN_AUS
	aktiv
TDA_CFG_IND_PDM_GR_NBR_M
	file0
TDA_CFG_TSM_TRIGGER
	all
TDA_FBLOCK
	fblock_df
TDA_TSM_ACTIVE
	aktiv
TELEMATIC_COUNTRY_VARIANT
	row
TELEMATIK_VIN
	coding_vin
TELEX_M
	aktiv
TEXT_NOTES_EIN_AUS
	aktiv
UNICODE_EIN_AUS
	nicht_aktiv
USB_HUB_M
	nicht_aktiv
VCARD_OVER_MOST_M
	aktiv
VENTILATION_CNTRL_ENABLED
	aktiv
VIDEO_PLAYER_EIN_AUS
	aktiv
BT_EIN_AUS_MED
	aktiv
OFFSET_BTAS
	wert_00
OFFSET_IPOD_SERIAL
	wert_00
COVER_ART_TWO_WIRE
	nicht_aktiv
ETHERNET
	nicht_aktiv
PAN_PROFILE_M
	aktiv
FOLLOW_UP_TIME_EXTENSION
	wert_02
SWUP_CYCLIC_MONITORING
	wert_20
SWUP_CYCLIC_RESET_TIMEOUT
	wert_255
SWUP_CYCLIC_RST_THRESHOLD
	wert_05
HANDSFREE_SECONDARY
	nicht_aktiv
combox
Code:
TYP_LENKUNG
	linkslenker
SPRACHE
	franzoesisch
BT_UFN
	wert_01
USED_MICROPHONES
	wert_01
PHONE_TYPE_JAPAN
	nicht_aktiv
RINGTONE
	ringtone_1
RSE_HIGH
	nicht_aktiv
	aktiv
	nicht_aktiv
BT_OBJECT_PUSH
	nicht_aktiv
	l4_mic
	wert_03
INBAND_RINGING
	nicht_aktiv
CONFIG_INDEX
	config_index_3
DPAS_INDEX
	dpas_3
	nicht_aktiv
A2DP_AVRCP_EIN_AUS
	aktiv
AKD_SUPPORTED_POIS
	wert_25
API_EIN_AUS_MED
	nicht_aktiv
API_IPOD_ONE_WIRE
	aktiv
	aktiv
API_TWO_USB_M
	nicht_aktiv
AUDIO_NOTES_EIN_AUS
	nicht_aktiv
AUDIO_SOURCE_FILE
	file_1
AUDIO_VERSTAERKER
	wert_01
	nicht_aktiv
CALENDAR_EIN_AUS
	aktiv
CAR_TYPE_IPOD_LOGO
	bmw
	nicht_aktiv
	nicht_aktiv
	nicht_aktiv
CONTACTS_EIN_AUS
	aktiv
DATACOMM_CSIM
	aktiv
DATACOMM_INTERFACE
	mamac
DRM_CHIP_ENABLED
	aktiv
DUN_PROFILE_M
	aktiv
EMAIL_EIN_AUS
	nicht_aktiv
	aktiv
	nicht_aktiv
GPS_FROM_MOST
	nicht_aktiv
	wert_01
	wert_15
HEAD_UNIT_MODEL
	cic_mid_rueko
	aktiv
	nicht_aktiv
	aktiv
IP_ROUTER
	aktiv
	nicht_aktiv
M_SECURITY_MODE_AEH
	des_cbc
M_SECURITY_MODE_AEP
	aes_128
M_SECURITY_MODE_ASH
	des_cbc_mac
M_SECURITY_MODE_ASP
	hmac_sha_256
MAIN_BOARD_ALONE
	ecallboard_present
MED_SVS_EIN_AUS
	aktiv
MMS_EIN_AUS
	nicht_aktiv
MULTI_PARTY_CALL_M
	aktiv
	wert_25
ONLINE_ROUTER
	aktiv
	last_first
	aktiv
PIM_BILDER_EIN_AUS
	aktiv
	wert_01
RDL_CONTROL
	aktiv
RDU_CONTROL_ENABLED
	aktiv
REMINDER_EIN_AUS
	aktiv
	aktiv
RESPONSE_ON_HOLD_M
	nicht_aktiv
	nicht_aktiv
SIM_ENABLED_MB
	csim
SMS_EIN_AUS_MED
	aktiv
SORTING_VARIANT_M
	standard
STARTUP_ACTIVE
	nicht_aktiv
SVR_ENABLED
	aktiv
	aktiv
	nicht_aktiv
	nicht_aktiv
SWUP_SOURCE_ONLINE
	nicht_aktiv
	nicht_aktiv
TASK_EIN_AUS
	aktiv
	file0
TDA_CFG_TSM_TRIGGER
	all
TDA_FBLOCK
	fblock_df
TDA_TSM_ACTIVE
	aktiv
	row
TELEMATIK_VIN
	most_vin
TELEX_M
	aktiv
TEXT_NOTES_EIN_AUS
	aktiv
UNICODE_EIN_AUS
	nicht_aktiv
USB_HUB_M
	nicht_aktiv
VCARD_OVER_MOST_M
	aktiv
	aktiv
	aktiv
BT_EIN_AUS_MED
	aktiv
OFFSET_BTAS
	wert_00
OFFSET_IPOD_SERIAL
	wert_00
COVER_ART_TWO_WIRE
	nicht_aktiv
ETHERNET
	nicht_aktiv
PAN_PROFILE_M
	aktiv
	wert_02
	wert_20
	wert_255
	wert_05
HANDSFREE_SECONDARY
	nicht_aktiv
I don't know what could still be wrong.
Old 11-17-2012, 05:06 PM
mcic
Code:
TYP_LENKUNG
	linkslenker
SPRACHE
	englisch
	koreanisch
	china_trad
	russisch
BT_UFN
	wert_01
USED_MICROPHONES
	wert_01
PHONE_TYPE_JAPAN
	nicht_aktiv
RINGTONE
	ringtone_1
RSE_HIGH
	nicht_aktiv
	aktiv
	nicht_aktiv
BT_OBJECT_PUSH
	nicht_aktiv
	l4_mic
	wert_03
INBAND_RINGING
	nicht_aktiv
CONFIG_INDEX
	config_index_3
DPAS_INDEX
	dpas_3
	nicht_aktiv
A2DP_AVRCP_EIN_AUS
	aktiv
AKD_SUPPORTED_POIS
	wert_25
API_EIN_AUS_MED
	nicht_aktiv
API_IPOD_ONE_WIRE
	aktiv
	aktiv
API_TWO_USB_M
	nicht_aktiv
AUDIO_NOTES_EIN_AUS
	nicht_aktiv
AUDIO_SOURCE_FILE
	file_1
AUDIO_VERSTAERKER
	wert_01
	nicht_aktiv
CALENDAR_EIN_AUS
	aktiv
CAR_TYPE_IPOD_LOGO
	bmw
	nicht_aktiv
	nicht_aktiv
	nicht_aktiv
CONTACTS_EIN_AUS
	aktiv
DATACOMM_CSIM
	aktiv
DATACOMM_INTERFACE
	mamac
DRM_CHIP_ENABLED
	aktiv
DUN_PROFILE_M
	aktiv
EMAIL_EIN_AUS
	nicht_aktiv
	aktiv
	nicht_aktiv
GPS_FROM_MOST
	nicht_aktiv
	wert_01
	wert_15
HEAD_UNIT_MODEL
	cic_mid_rueko
	aktiv
	nicht_aktiv
	aktiv
IP_ROUTER
	aktiv
	nicht_aktiv
M_SECURITY_MODE_AEH
	des_cbc
M_SECURITY_MODE_AEP
	aes_128
M_SECURITY_MODE_ASH
	des_cbc_mac
M_SECURITY_MODE_ASP
	hmac_sha_256
MAIN_BOARD_ALONE
	ecallboard_present
MED_SVS_EIN_AUS
	nicht_aktiv
MMS_EIN_AUS
	nicht_aktiv
MULTI_PARTY_CALL_M
	aktiv
	wert_25
ONLINE_ROUTER
	aktiv
	last_first
	aktiv
PIM_BILDER_EIN_AUS
	aktiv
	wert_01
RDL_CONTROL
	aktiv
RDU_CONTROL_ENABLED
	aktiv
REMINDER_EIN_AUS
	aktiv
	aktiv
RESPONSE_ON_HOLD_M
	nicht_aktiv
	nicht_aktiv
SIM_ENABLED_MB
	csim
SMS_EIN_AUS_MED
	aktiv
SORTING_VARIANT_M
	standard
STARTUP_ACTIVE
	nicht_aktiv
SVR_ENABLED
	aktiv
	aktiv
	nicht_aktiv
	nicht_aktiv
SWUP_SOURCE_ONLINE
	nicht_aktiv
	nicht_aktiv
TASK_EIN_AUS
	aktiv
	file0
TDA_CFG_TSM_TRIGGER
	all
TDA_FBLOCK
	fblock_df
TDA_TSM_ACTIVE
	aktiv
	row
TELEMATIK_VIN
	coding_vin
TELEX_M
	aktiv
TEXT_NOTES_EIN_AUS
	aktiv
UNICODE_EIN_AUS
	nicht_aktiv
USB_HUB_M
	nicht_aktiv
VCARD_OVER_MOST_M
	aktiv
	aktiv
	aktiv
BT_EIN_AUS_MED
	aktiv
OFFSET_BTAS
	wert_00
OFFSET_IPOD_SERIAL
	wert_00
COVER_ART_TWO_WIRE
	nicht_aktiv
ETHERNET
	nicht_aktiv
PAN_PROFILE_M
	aktiv
	wert_02
	wert_20
	wert_255
	wert_05
HANDSFREE_SECONDARY
	nicht_aktiv
combox
Code:
TYP_LENKUNG
	linkslenker
SPRACHE
	franzoesisch
BT_UFN
	wert_01
USED_MICROPHONES
	wert_01
PHONE_TYPE_JAPAN
	nicht_aktiv
RINGTONE
	ringtone_1
RSE_HIGH
	nicht_aktiv
	aktiv
	nicht_aktiv
BT_OBJECT_PUSH
	nicht_aktiv
	l4_mic
	wert_03
INBAND_RINGING
	nicht_aktiv
CONFIG_INDEX
	config_index_3
DPAS_INDEX
	dpas_3
	nicht_aktiv
A2DP_AVRCP_EIN_AUS
	aktiv
AKD_SUPPORTED_POIS
	wert_25
API_EIN_AUS_MED
	nicht_aktiv
API_IPOD_ONE_WIRE
	aktiv
	aktiv
API_TWO_USB_M
	nicht_aktiv
AUDIO_NOTES_EIN_AUS
	nicht_aktiv
AUDIO_SOURCE_FILE
	file_1
AUDIO_VERSTAERKER
	wert_01
	nicht_aktiv
CALENDAR_EIN_AUS
	aktiv
CAR_TYPE_IPOD_LOGO
	bmw
	nicht_aktiv
	nicht_aktiv
	nicht_aktiv
CONTACTS_EIN_AUS
	aktiv
DATACOMM_CSIM
	aktiv
DATACOMM_INTERFACE
	mamac
DRM_CHIP_ENABLED
	aktiv
DUN_PROFILE_M
	aktiv
EMAIL_EIN_AUS
	nicht_aktiv
	aktiv
	nicht_aktiv
GPS_FROM_MOST
	nicht_aktiv
	wert_01
	wert_15
HEAD_UNIT_MODEL
	cic_mid_rueko
	aktiv
	nicht_aktiv
	aktiv
IP_ROUTER
	aktiv
	nicht_aktiv
M_SECURITY_MODE_AEH
	des_cbc
M_SECURITY_MODE_AEP
	aes_128
M_SECURITY_MODE_ASH
	des_cbc_mac
M_SECURITY_MODE_ASP
	hmac_sha_256
MAIN_BOARD_ALONE
	ecallboard_present
MED_SVS_EIN_AUS
	aktiv
MMS_EIN_AUS
	nicht_aktiv
MULTI_PARTY_CALL_M
	aktiv
	wert_25
ONLINE_ROUTER
	aktiv
	last_first
	aktiv
PIM_BILDER_EIN_AUS
	aktiv
	wert_01
RDL_CONTROL
	aktiv
RDU_CONTROL_ENABLED
	aktiv
REMINDER_EIN_AUS
	aktiv
	aktiv
RESPONSE_ON_HOLD_M
	nicht_aktiv
	nicht_aktiv
SIM_ENABLED_MB
	csim
SMS_EIN_AUS_MED
	aktiv
SORTING_VARIANT_M
	standard
STARTUP_ACTIVE
	nicht_aktiv
SVR_ENABLED
	aktiv
	aktiv
	nicht_aktiv
	nicht_aktiv
SWUP_SOURCE_ONLINE
	nicht_aktiv
	nicht_aktiv
TASK_EIN_AUS
	aktiv
	file0
TDA_CFG_TSM_TRIGGER
	all
TDA_FBLOCK
	fblock_df
TDA_TSM_ACTIVE
	aktiv
	row
TELEMATIK_VIN
	most_vin
TELEX_M
	aktiv
TEXT_NOTES_EIN_AUS
	aktiv
UNICODE_EIN_AUS
	nicht_aktiv
USB_HUB_M
	nicht_aktiv
VCARD_OVER_MOST_M
	aktiv
	aktiv
	aktiv
BT_EIN_AUS_MED
	aktiv
OFFSET_BTAS
	wert_00
OFFSET_IPOD_SERIAL
	wert_00
COVER_ART_TWO_WIRE
	nicht_aktiv
ETHERNET
	nicht_aktiv
PAN_PROFILE_M
	aktiv
	wert_02
	wert_20
	wert_255
	wert_05
HANDSFREE_SECONDARY
	nicht_aktiv
Do you have a tethering plan on your phone?
Does Data Connection show under phone as an option?
- BMWCCA #446923
- flick
Old 11-19-2012, 10:49 AM
Today I check it with Iphone 4 GS,Samsung Galaxy S III, Samsung Galaxy Ace, Nokia N73 and everywhere the same result:
Maybe in the business version is not work?
My SW: TX-002.005.025-002.005
My fa.trc :
E90_#0910&EBAT%0475$1CA$1CB$1CC$1CD$216$230$249$255$2K9$2PA$ 320$321$423$428$441$464$465$4CG$508$520$521$534$54 0$548$606$614$615$616$644$698$6AA$6AB$6AL$6VC$863$ 881$8A1$8S3$8TL$8TN-A090
Old 11-19-2012, 01:55 PM
My fa.trc :
I am not sure about Business vs. Professional.
Apart from testing many different phone models, I was asking if you have an actual paid Tethering / Hotspot plan with your Cell Phone provider?
- BMWCCA #446923
- flick
Old 11-19-2012, 02:27 PM
Yes,Iphone and Galaxy S III have an actual paid Tethering / Hotspot
Besides, on this website
http://www.bmw.de/de/de/owners/conne...check_tool.jsp
"BMW internet" business version does not work with any phone.
Old 11-20-2012, 04:16 AM
I have read that it requires 6VC Combox and 609 Navigation, but then I have also heard that 609 isn't actually required, so I am not really sure.
- BMWCCA #446923
- flick
Old 11-20-2012, 04:55 AM
it seems that the "BMW Internet" in 606 only works with built-in SIM card. But I will keep try.
Old 11-20-2012, 06:01 AM
SA633 or SA639 (BMW Assist) and SA614 (Internet) = CAR SIM / Data Connection
SA644 and SA614 = Mobile Phone SIM / Data Connection
This is why you must kill BMW Assist to enable Bluetooth Tethering.
- BMWCCA #446923
- flick
Old 11-20-2012, 07:54 AM
That's how I did, but it didn't work so far
Old 12-03-2012, 11:43 PM
I don't have my login information on the BMW Online, maybe this is the problem?
Old 12-04-2012, 08:31 AM
No, that is not it, as it is not required.
- BMWCCA #446923
- flick
Old 01-15-2013, 05:35 PM
leonlee998 leonlee998 is offline
Mein Auto: f25x328i
For writing a VIN to the Combox in E-Sys, I figured that out, and it is very simple:
So simple in fact, that I am mad I spent so much damn time in Tool32, CMEDIA.prg and E-Sys trying to figure it out.
First you must code CMB_MEDIA / TELEMATIK_VIN = Coding VIN using your real FA VIN. Then, open your FA up in the FA-Editor, change the VIN, Caluclate FP just to make sure there are no problems with it, and then save the FA with a new name, i.e. FA_VIN_FAKE. Lastly, go to the coding module, and under Vehicle Order load your new FA_VIN_FAKE, activate FA, and then FDL code CMB_MEDIA. Lastly, read CMB_MEDIA coding data, and verify the new VIN in brackets. In the attached picture, you can see my Combox and Head Unit are showing two different VIN's.
Afterwards, either shut down E-Sys, or load your original FA back and activate it before coding anything else. DO NOT code anything else with this FA, and DO NOT write this FA to the car.
For Internet and BMW Live to work, you need a VIN with factory options 614 and 615.
Thank you!
I will try it.
but the country VO $866 will have an impact?
my VO include:
609,614,615,616,620,644,654,676,6aa,6ab,6ak,6al,6a m,6ap,6ar,6fv,6nf,6nl,6nr,6va,6vb,6vc,7sp,866
Old 01-15-2013, 06:14 PM
Originally Posted by leonlee998 View Post
Thank you!
I will try it.
my VO include:
Ok, and make sure on the last part you FDL Code CMD_MEDIA. If you mistakenly VO Code it, TELEMATIK_VIN will revert to MOST_VIN, and it will not take the new VIN.
I am not sure about 866. That is for Chinese Language, but it is not the same as a Country Controller code like one of the 8Lx codes (e.g. S8LHA Country controller for Hong Kong).
- BMWCCA #446923
- flick
Old 01-15-2013, 06:37 PM
Mein Auto: f25x328i
my real vin VO for:
609,676,6nk,6vc (star from 6)
and i have National version China: L8AA. remove this one?
Zeitkriterium=0411 ,this one need to change?
Old 01-15-2013, 06:56 PM
my real vin VO for:
I really don't know if L8AAA National version China needs to be removed or not, and if doing so has other effects.
I would leave it and try it, and then if you can't get it working, then remove it.
Your Production Date of 0411 should be fine as it is.
- BMWCCA #446923
- flick
Old 01-16-2013, 01:09 AM
Mein Auto: f25x328i
I write two VIN with 614,615,but not work still.
and i remove 8AA but lose navi.
and i try to add VO 8AA not succeed.
and i tick then code defult values with CIC. everything goto factory .
i try to code SVT, but at last CIC retune error and factory setting still..
can you help me do something!!!
Old 01-16-2013, 06:06 AM
Mein Auto: f25x328i
I GOT THIS ERROR FOR CODE AND FDL HU_CIC:
Caf's werden gesucht
Tal wird generiert
NCD werden gelesen
FDL CAFD-000000F9-07.03.0B signieren.
Abarbeitung wird gestartet
TAL execution started. [C205]
ExecutionID=2013/01/16-19:30:21.058
[] prepareTALExecution started
[] prepareTALExecution finished
[] prepareVehicleForCoding started
[] prepareVehicleForCoding finished
[HU_CIC - 63] prepareECUforCoding started
[HU_CIC - 63] prepareECUforCoding finished
[HU_CIC - 63] authenticateECUforCoding started
[HU_CIC - 63] authenticateECUforCoding finished
[HU_CIC - 63 - cafd_000000f9-007_003_011] Transaction type: cdDeploy; Message: TA started
MCDDiagService
[HU_CIC - 63 - cafd_000000f9-007_003_011] Transaction type: cdDeploy; Message: TA finished
[HU_CIC - 63] finalizeECUCoding started
[HU_CIC - 63] finalizeECUCoding finished
[Exception - HU_CIC - 63] job failed with negative response error:
code: service returned global negative response
description: Service WDBI_PLAIN returned a negative response with response code conditionsNotCorrect; ECU: HU_CIC_63_ETHERNET
severity: ERROR
[] finalizeVehicleCoding started
[] finalizeVehicleCoding finished
[] finalizeTALExecution started
[] finalizeTALExecution finished
TAL execution finished
TAL-Execution finished with status: "FinishedWithErrorInTransaction". [C207]
TAL execution finished. Duration: "31s". [C206]
Abarbeitung beendet
Old 01-16-2013, 06:13 AM
You should NEVER have hit the Code Defaults button.
I will contact you shortly via Blackberry.
- BMWCCA #446923
- flick
Old 01-16-2013, 06:21 AM
Mein Auto: f25x328i
I hit once time,but code ECUs restored.
But this time I can't, because before removed the 8AA VO.
