F10 Coding Internet over Bluetooth and not over BMW - Page 9 - Bimmerfest - BMW Forums
Old 04-08-2013, 08:37 PM
pacoj pacoj is offline
Mein Auto: F25 X3
thanks tristras
I will try it again
Old 04-08-2013, 09:56 PM
Mein Auto: F25 X3
Thanks tristras
I have try it but why when I do the VO code then everything change to origin
(i.e ONLINE_BROWSER = beide_aktiv => no aktiv
ONLINE_BROWSER_LIVE = aktiv => nu aktiv
ONLINE_SERVICES = aktiv => nu aktiv
ONLINE_SERVICES_GLS = aktiv => nu aktiv
Did I do anything wrong??
Old 04-09-2013, 06:18 AM
Mein Auto: F25 X3
Hi shawn,
It's doesn't show any BMW online and internet on my CIC
after when I coding the
it's show under the connect drive => BMW online and Internet
but just that I show you the picture, I can't use it
Why is this happen??
Old 04-09-2013, 07:58 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
Originally Posted by pacoj View Post
Hi shawn,
Do not worry about these individual FDL Codes. If you VO Code HU_CIC and CMB_MEDIA with VO that has the correct Option Codes, these will be set correctly.
You posted your VO earlier with the following Option Codes:
  • 614_PREPARATION_INTERNET
  • 615_EXTENDED_BMW_ONLINE_INFO
  • 6AB_CONTROL_BMW_TELESERVICES
  • 6VC_CONTROL_COMBOX
  • 6AL_BMW_LIVE
  • 6NK_EXT_CONNECTION_MOBILE_EQUIPMENT
Are these all factory options, or did you add any of these to your VO, and if so, which ones?
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 04-09-2013, 09:15 AM
Mein Auto: F25 X3
I add 614, 615, 616, 6AB, 6AL, 644
Old 04-09-2013, 09:20 AM
Mein Auto: F25 X3
but when I VO Code HU_CIC and CMB_MEDIA
those CAFE code have change back to origin setting
I don't know what's happened, it's just happened with those online code, others is fine
Old 04-09-2013, 09:21 AM
So now you have both 644 and 6NK? You only need 6NK.
In any event, did you follow the detailed instructions to write VIN with factory options 614 and 615 to Combox?
Old 04-09-2013, 09:23 AM
Maybe you used factory VO, and not modified VO.
Old 04-09-2013, 09:29 AM
Mein Auto: F25 X3
sorry what's mean is used factory VO, and not modified VO. ??
Old 04-09-2013, 09:31 AM
Mein Auto: F25 X3
so I'll delete the 644?? I follow that you give me "How to code FA to F Car" to add those VO
Old 04-09-2013, 09:34 AM
Mein Auto: F25 X3
O~~~I SEE yes I used factory VO not FAK_VIN VO
so you mean I need use FAK_VIN VO to code FDL in HU_CIC and CMB_MEDIA??
Old 04-09-2013, 09:39 AM
Mein Auto: F25 X3
but when I use FAK_VIN to code and code FDL it's have error message
Old 04-09-2013, 09:45 AM
Mein Auto: F25 X3
to what combox??
I have find a car as same as me but he have 614 and 615 VO so I write his VIN to My FAK_VIN
Old 04-09-2013, 09:47 AM
Yes, you need to remove 644 from modified VO.
Yes, you need to VO Code with modified VO. If you do not, how else then are the HU_CIC and CMB_MEDIA modules going to get configured to support the newly added options?
You are getting the error probably becuase you have the Fake VIN in the VO, but CMB_MEDIA => TELEMATIK_VIN is set to MOST_VIN.
This is very complicated and detailed to get working. I have written step-by-step instructions that must be followed exactly, or it will not work. If you do not follow the instructions, do not expect it to work.
Old 04-09-2013, 09:48 AM
to what combox??
Yes. You will use his VIN with factory 614 and 615 and write it to the Combox, but again, you must follow the steps exactly as they are written.
Old 04-09-2013, 10:25 AM
Mein Auto: F25 X3
1.
Coding => Read FA => Read VCM =>
HU_CIC:
CONNECTED_DRIVE = aktiv
ONLINE_BROWSER_LIVE = aktiv (if also +6AL)
CMB_MEDIA:
TELEMATIK_VIN = Code_VIN.
SIM_ENABLED_MB = csim
DATACOMM_CSIM = aktiv
DUN_PROFILE = aktiv
press code FAL
2, edited the my original FA file:
Read FA, Save as a New FA, then click Edit Button,
Add SALPA to followings (if you don't have in your FA) : 614, 615, 6AB, and 6AL
Then Calculate FP, if no error, save it
3, To VO code new SALPA elements to the car:It's will follow "How to code FA in F car
Load the saved New FA file, then activated it. (you don't need to write this FA the car)what's mean I don't need to write this FA the car.
VO code the Media and HU_CIC Is it use New FA right??
Reset your CIC unit by pressing the mute button while 20-25 seconds.
-Wait 1-2 minutes after the CIC Unit starts, Check BMW Live and Internet is there,
-If Yes, everything is OK, follow the next step. so after this two step I can use BMW online and Internet??
4, Create a FA file with FAKE VIN number
-Before this step, don't forget the change TELEMATIK_VIN = Coding_VIN and FDL code it,
-Find a VIN number which has 614 and 615 in factory. www.bmwvin.com will help you to decode your fake VIN.
-Load your New FA file which has been created on first step, then save as Fake FA and Click Edit button.
-Replace your original VIN number with a FAKE VIN, then Calculate FA and Save it.
-Load the FAKE FA, activate it and FDL code to MEDIA CAFD.
-Read the VCM, and Read the MEDIA ECU, that will show the FAKE VIN.
-If it is OK, Reset you CIC Unit again, and connect your BT and Update connectedrive Services ones.
-When update completed, try Internet and Live. Must Work
-After that, Load your the New FA which is on first step, Activate it and Read the MEDIA ECU.
-Edit FDL, Change the TELEMATIK_VIN = MOST_VIN.
-Save it, and FDL code to the car.
-Everything will work but be careful, don't update connectedrive services any more.
Is it a right instructions??
Sorry Shawn you are so pro that I don't understand some code your write so I follow the erdengurcan's step
If it's done. After I can't do any coding from origin FA, right??
Old 04-09-2013, 10:52 AM
1.
HU_CIC:
CMB_MEDIA:
DUN_PROFILE = aktiv
press code FAL
This looks mostly right, but this:
No. Why would you think you could start using BMW online and Internet in the middle of the procedure, and especially before FAKE VIN is written to Combo? You must complete the entire process first.
Old 04-09-2013, 05:20 PM
Mein Auto: F25 X3
sorry I mean that my CIC will can be select the Bmw online and internet
not like I had post the picture that reverse blue and can't use it
Old 04-09-2013, 08:45 PM
The Internet will only become selectable after the fake VIN is written to the Combox and BMW Services is updated and reflects Internet as an available service.
Old 04-10-2013, 02:58 AM
Mein Auto: F25 X3
Hi Shawn,
Is it update from "BMW TelServices"?
Why I can not update it??
I have 3g network on my iphone also have link bluetooth with the car.
Old 04-10-2013, 09:28 AM
Hi Shawn,
Under iDrive Options Service Status, there should be a means to Update your available services, after which Internet and BMW Live would appear when using the Fake VIN in Combox:
Name:	Update BMW Assist.jpg
Name:	Available Services.jpg
Old 04-10-2013, 07:59 PM
Mein Auto: F25 X3
Hi Shawn,
I have update the software today but it's only update battery protection and teleservice report.
I still can't use internet and bmw live
Is it have been lock or something wrong??
Old 04-10-2013, 09:15 PM
Hi Shawn,
And you are positive when you updated it, the Fake VIN with factory 614 and 615 was written to Combox at the time of update?
Old 04-11-2013, 06:41 AM
Mein Auto: F25 X3
Hi Shawn,
Yes I have
When I doing the VO code load from New FA
VO CODE HU_CIC
VO CODE CMB_MEDIA
the CMB_MEDIA => TELEMATIK_VIN = Code_VIN become Most_Vin(after I Have change back to code_vin)
also the HU_CIC all "Online" code become "nu aktiv"
Is it correct to change back to origin code ?? Or I do something work
sorry to disturb you so much time
Old 04-11-2013, 10:36 AM
Hi Shawn,
Yes I have
VO CODE HU_CIC
VO CODE CMB_MEDIA
I don't know. The VIN you have in the Combox is good, I just checked it. So, assuming also that just prior to this step you VO coded HU_CIC and CMB_MEDIA with 614, 615, 6AL and 6AB, you should just Update Services, and Internet and BMW Live should be enabled in the list of services.
What is the Build Date of your Car?
