E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008)
Coupe and Roadster talk with our gurus here... |
Windscreen washer problem
The windscreen washer has stopped working, a few drops of water emerge for a couple pf second but then stop. Pump runs ok and pipes do not seem to be blocked. Wipers work OK.
I dont know what the electrical wiring does that enters the rear of the piddler pipe units, could this be the source of the problem, an electrical failure. All relevant fuses are OK ! Would welcome some help! Thanks Last edited by Pocalin; 07-28-2012 at 06:40 AM. |
just basic washer pump info........check flow close to the pump,if its still weak look for dirt in pump/tank
Pocalin. I had close to the same issue when I bought my Z3. Like Wifesauto stated, I ended up taking the pump out of the tank and the screen was clogged with dirt/sludge. Took about 5mins(ish) total time to take the tank off, pull the electric pump, clean the screen and rince the tank, and reinstall. Not hard to do. Good luck.
S. Maykowski, Columbus MS. ![]() My '99 Z3 Alpine White 2.8L Speed Buggy |
The wiring under the hood is for heaters in the nozzles.
I understand that the water bottle is slightly different for European and American versions. For my american version, there is only one plasic screw that holds the bottle in and the pump is held in place only by friction in a rubber O-ring. To clean it, you just unscrew the screw, lift the bottle out, and pull the pump out of the bottle. |
Ok so I just worked on my mom's Z3 and fixed the problem. I took the tank out and looked at the filter, as recommended. The filter was perfectly clean. I also checked all the fuses. Had my mom hit the washers while the engine bay was open, no windshield washer motor noise (but the wipers worked). Went to the local BMW dealership and got a new motor, which was like $70, but no auto parts stores carry them or will even order them. Put the new motor in and it worked perfectly.
So my suggestion to anyone who has the same issue in the future is to listen for the motor that controls the washer system, it's attached to the side of the washer fluid tank and it's pretty loud. I never work on my own cars, not even for oil changes, but I was able to fix this issue in five minutes so it's super easy.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
