Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X1 E84 (2011 - current)
The new to the US BMW X1 will arrive at BMW dealers in the fall of 2012 as a 2013 model year. Get your X1 28i with either sDrive (RWD) or xDrive (AWD) or get the US exclusive I6 N55 powered X1 35i dDrive.
Old 07-28-2012, 10:24 AM
X1blue X1blue is offline
Mein Auto: X1 sdrive 18d
X1 making the family sick..
Finally took the new car out on the motorway for a 3hr drive and for the first time ever we all arrived at the hotel feeling sick. My wife had a pain in her neck and a horrible headache. The baby vomited on route and cried a lot. I felt quite sea-sick and I was driving (and on dry land!!)
The X1 has unbelievably hard suspension which makes it 'rock' when one wheel encounters a bump or any kind of undulation in the road. The motorway is well used in parts but it is not that bad and we rarely exceed 110km (on cruse control) with no head or side winds.
Is this happening to anyone else?
Old 07-29-2012, 07:35 AM
speedracerf4i speedracerf4i is offline
Mr. Registered User
Mein Auto: 2005 545i
Maybe changing your run-flat tires to regular tires may help.
MY05 545i SMG, sport-pack, L7, comfort seats, Navigation, Auburn Dakota leather/Jet Black. Euro-delivery.[COLOR=Navy]
1998 318Ti M-Pack Hellrot Red, 5 Speed.
2013 Jet Black X1 ED October pick up.
Old 07-29-2012, 07:53 AM
bimmerized bimmerized is offline
Mein Auto: 97 E36M/4
any kind of swaying would point to defective shocks. have those checked and take a ride in another X1 with the same suspension to see if there is an obvious difference. If the suspension were stiff enough to pitch the car, you would have the sensation of being thrown from your seat.
Old 07-29-2012, 08:18 AM
The tires are standard tires, not run-flats. In Europe you have to buy this option.
The car goes back next week for tests, hope they find what is wrong with it as not being able to drive it on the motorway is a small problem... the sales guy said the ride is hard but shouldn't make us motion sick.
Old 07-29-2012, 02:11 PM
investor27 investor27 is offline
Mein Auto: Camero GT
Not true. What he was describing sounds like tramlining, which is normally found in almost every car. The size and type of your tyres contribute to this.
Old 07-30-2012, 12:58 AM
Well I looked up tramlining and this is road surface related. The car does go left or right depending on the road slope but this is not the problem. Our previous car did the same, the problem with this on the X1 is the very heavy steering which makes you work a lot correcting this movement.
The problem I am referring to is vertical and rotational movement. The car is transmitting the smallest imperfections in the road to the passengers. Bumps, holes, ripples in the surface, hardly anything gets taken out of the ride. The vertical movement is virtually constant. The rocking comes from one wheel (or one side) passing over an imperfection and instead of the socks talking the energy, the car rolls.
It is this virtually constant vertical and rotation movement which is making us sick. The headaches probable come from all the bouncing vertically. You just need to put a finger on the back of your neck while moving in the X1 to feel the amount of strees being transmitted up the spine to the base of the head.
Old 07-30-2012, 07:48 AM
Mr. Registered User
[QUOTE=X1blue;6978726]The tires are standard tires, not run-flats. In Europe you have to buy this option.
QUOTE]
Just curious, if you don't get standard RFT, then you must get a spare wheel right?
I did not see a space for spare wheel in any U.S. X1 videos, but I am willing to buy 1 after ditching the original RFT's. If I can't fit a spare wheel somewhere, then I will have to choice but to be doomed to a life of RFT's.
Old 07-30-2012, 08:21 AM
HotRodW HotRodW is offline
Mein Auto: 2013 X1, 2012 Q5
[QUOTE=speedracerf4i;6980288]
QUOTE]
Fix-A-Flat. I will probably run the OEM runflats until they're used up, get damaged by one of our famous Michigan potholes, or until I simply can't stand the compromised ride any longer, then I'll replace them with conventional tires, put a couple cans of Fix-A-Flat in the car, and hope for the best.
Rod
2013 X1 xDrive28i M Sport
2012 Q5 2.0T
2002 RSX
Old 07-30-2012, 11:59 AM
QUOTE]
No, the X1 here comes with a a liquid kit as standard. You have to order the wheel option and we didnt. Regretting that now as I was upgraded to an Audi A3 at the airport recently and this also had no spare. And course as luck would have it, the first puncture in 20 years was lateral and around 4mm, the limit for the Audi kit.. When the rental company sent a truck 'to help' they could only take the car to the nearest Audi..
Old 07-30-2012, 02:11 PM
Lavalamp425 Lavalamp425 is offline
Lurker
Mein Auto: E92 335i
You might check to see if there are shipping spacers up in the suspension. It is not common, but sometimes the port forgets to remove these so the car rides high and rough (minimal suspension travel). Of course, our cars have to be shipped on boats over from Europe and I'm not sure what BMW does when shipping cars via truck or rail within Europe.
2007 E92 335i
ex 1991 E34 525i (M50)
Old 07-30-2012, 11:17 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: BMW X3
get rid off RFT
06 130i
07 320i
08 E92 325i
Bicycles: Giant TCR Advanced Zero, Argon 18 Krypton
NEXT CAR : A PORSCHE
Old 08-14-2012, 12:07 AM
Originally Posted by SilverX3 View Post
get rid off RFT
RFT in Europe are a 300 euro option which we didnt buy. We have standard 225/50 R17 94 H MICHELIN Primacy HP tyres.
Old 08-14-2012, 06:50 AM
the_fox's Avatar
the_fox the_fox is offline
Custom User
Mein Auto: X1
X1blue, I recommend you rent another X1 for a longer trip (or ask your dealer for a loaner). Then you will have a definite answer whether this is a design issue with all X1s or if yours has a defect that needs servicing.
Do not fold, staple, or mutilate. Void where prohibited.
Old 08-14-2012, 08:06 AM
If the dealer had let us take one for a longer ride, I dont think we would be in this mess now. We have an Audi or a Range Rover.. they only let you ride in the city for 45mins and always with someone from the dealership.
Were on holiday in a rental at the moment, lets see if we can get another dealer to lend us one..
Old 08-15-2012, 08:13 PM
casper casper is offline
Mein Auto: F10 550i
maybe it was something you ate before.
2011 550i Msport
Carbon Black/Cinnamon/PP2/sport auto/
2010 335i Conv Sport auto
2008 550i Msport auto
2004 545i sport auto
2003 Z4 3.0 sport auto
2001 530i sport auto
2001 X5 sport auto
1999 740il auto
1996 540i auto
1995 M3 manual
1991 525i auto
1987 325is sport manual
1982 320is sport manual
1981 320is sport manual
1979 320is sport manual
Old 08-16-2012, 06:28 AM
ubermax ubermax is offline
Mein Auto: '08 Volvo S60, '97 Jetta
we have an '08 X3 & it had a trucky ride from the start, especially noticeable for rear seat passengers - we had a used Audi A6 for awhile and the ride was very cushy in comparison - but most of the roads that we travel are fairly smooth and the relatively stiffer ride is a small con compared to the many pluses of the X3 - I realize we're talking X1 but I'm assuming the suspensions of all X models are of similar design & components.
sounds to me like (1) the suspension of the X1 is a dramatic change from what you were driving before (2) you were essentially "off road" driving or (3) the shocks & struts need replacing .
good luck !!!!
Old 08-17-2012, 01:12 AM
We drove it 5 times for more than 1hr before taking it back for servicing, and each time we felt bad around 1hr after leaving home.
Dont you tend to sweat with food poising? We all just felt as we do when we take long boat rides.. we all suffer from sea sickness, we just dont usually get sick in the car. X1 makes us sick even on pretty good motorway surfaces, it seems to pickup and amplify the slightest imperfection on the road.
Old 08-17-2012, 01:15 AM
good luck !!!!
The car is 5 weeks old, so the suspension should be OK but this is BMW...
The suspension (and wheels) are very different from our old VW Golf, indeed from any rental I have driven over the past 10 year. I have never been in a car that jolts, jumps and vibrates so much.
At least with the X1 you can put Electronic Damper Control (EDC) but the X1 does not have this option (even though they now put it on Series 1, 3, 5 and 7 cars)
