new left xenon bulb won't work - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 07-29-2012, 08:07 PM
gonzts gonzts is offline
Mein Auto: 328i
Have '07 328i. Had to remove cover from under wheel well to access bulb. Went to dealer for new bulb ($300), replaced bulb, and still won't work. Its a one piece bulb. Right side still works fine. fuses 56&57 are good. Still have light indicator in dash. Car still in air. Any Ideas? Please help. Getting ready to go to dealer.
Old 09-22-2012, 03:39 AM
BMWFatherFigure's Avatar
Old School
Why did you think the 'globe' has blown? Xenon globes have 12yr life (typical). Tyry the rh globe in the lh unit and put your new globe in the working side to test it. I guess the lhs will still not work. Start changing components r to l until you make the lh work. That is the part you should have bought..
Current:
E38 Parts Car
Previous:
