Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Classic Bimmers
Classic Bimmers
Discussions pertaining to vintage and classic BMW models here...
Old 07-29-2012, 09:15 PM
pcstudio pcstudio is offline
Mein Auto: Honda, Porsche, BMW
Unhappy Trouble shooting ignition, novice mechanic
1972 Bavaria, I have an ignition problem. Car suddenly refused to start, no dash lights, no sound from the starter. Replaced the battery, dash lights work but starter just clicked and clicked but did not turn over, Replaced the starter, still clicks, but will not turn over.
Please outline next steps to finding the issue. Thanks
Old 07-30-2012, 12:18 PM
john@eac john@eac is offline
Past Sponsor
Mein Auto: Many
You need to check your battery cables, make sure that you have a good connection. You need to make sure you have a good ground too. I have seen cables go bad that look fine only to be broken at the terminal end.
Cover your basics.
Old 08-11-2012, 09:35 PM
BMWFatherFigure's Avatar
Old School
How good was the replacement battery?
Old 08-17-2012, 03:32 AM
Interstate replacement battery, was faulty AND so was cable from battery to starter.
I now have a new problem.
TURN signal AND Hazard flasher work on left front only.
NO signal to right or rear. How do if find the break in power supply to the RT and rear?
By the way your help on the ignition issues was excellent. Thanks
Old 08-19-2012, 05:50 AM
Old School
Possibly contacts in the hazard warning switch. Select right flasher (with ign on) and keep working the hazard switch. Maybe spray in a LITTLE switch cleaner too - same treatment for the flasher switch as well. If lefts are working its not fuse or flasher unit. Check globes - you never know...........
Old 08-22-2012, 03:09 PM
Old School
Did that work?
