E34 (1989 - 1995)
Old 07-30-2012, 09:28 AM
Beamerbroken Beamerbroken is offline
Mein Auto: 2000 BMW 740IL
Cool 1995 540i Transmission fluid
What kind of transmission fluid do I need for my 1995 540i?
Old 07-30-2012, 03:41 PM
goosefoot33's Avatar
goosefoot33 goosefoot33 is offline
Manualaholic
Mein Auto: 01 330Ci/02 525iT
Manual or automatic?
How many miles on it?
Has the fluid been changed before?
What is the model of the transmission?
Sent from my Droid Incredible
BMWCCA Member# 451235
(Summer) 2001 330Ci - ZSP
(Winter) 1994 530i "Greenie" - PARTING OUT! (PM for details)
(Grocery Getter) 2002 525iT
Old 07-31-2012, 09:34 PM
Costa's Avatar
Costa Costa is offline
Mein Auto: Supercharged E34 540i6
+1 is it a 5HP-24, or a 5HP-30?
Old 08-03-2012, 11:34 AM
air_cooled air_cooled is offline
Mein Auto: E39 / E30 / E53
5HP30 (AS5 560Z) requires Shell LA2634. BMW states use of other oil will cause failure, however, some have used Amsoil ATF, Penzoil, Valvoline MAXLIFE with success.
INFO :
https://wiki.bentleypublishers.com/d...+transmissions
Old 08-03-2012, 03:44 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
Penzoil was the most cost effective for me when ive done the later BMW transmissions, i have the bottle in the shed if you would like me to find out exactly what i used
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 08-07-2012, 08:51 AM
The transmission is automatic. 200004 miles. The fluid was supposed to be changed years ago. I will need to locate the transmission model. I do not know it.
Old 08-07-2012, 12:41 PM
ThoreauHD ThoreauHD is offline
Mein Auto: 02/1994 530i 8cylinder
Not really.
Redline D4ATF x 4
Redline 75w-90 x 2
Automatic transmission filter kit
That's it.
Old 08-07-2012, 06:42 PM
Manualaholic
I would not change the fluid if it was supposed to be changed many years ago, unless you absolutely know it was changed on a regular basis (i.e. every 40-60k miles). I would instead save your money for a nice rebuilt unit.
Changing the fluid after even 100k miles for the first time is an invitation for tranny failure.
A quick example: I sold a few parts to a guy who bought an e34 cheap, to flip. He changed the tranny fluid and suddenly the tranny did not work at all. The old fluid was actually a "part" of the transmission, and helped it work.
Old 08-09-2012, 08:24 AM
ross1's Avatar
ross1 ross1 is offline
Mein Auto: Pretty much had 'em all
If this happens the trans was at death's door anyway.
Friction material circulating in the oil that may be providing grip to worn clutches is also wearing bearing and seal surfaces at an exponential rate.
Don't change the oil and it will die, change the oil and maybe it will die.
Take my advice, I'm not using it.
Old 08-09-2012, 03:57 PM
Manualaholic
Originally Posted by ross1 View Post
Don't change the oil and it will die, change the oil and it will die.
^^ Fixed
Auto trannies have a limited lifespan. At 200k, the tranny (original I am assuming) is on its way out regardless of whether or not you change the oil. I think we need to find out from the OP why exactly he is changing his oil in the first place: strange sounds, slipping, maintenance item, just for the heck of it?
Old 08-17-2012, 06:03 AM
SwissCheeseHead SwissCheeseHead is offline
Mein Auto: 08 G37,94 530i,11 328iT
I'm also looking to change my ATF, for maintenance reasons. It's got 97K miles on it and I want to use Redline specs stated above. The tranny seems fine to me, but I don't know what it felt like new. I agree with ross1. It's better to change it than not. I've read that you should change it, drive it for 15K miles, then change it again to get all of the old stuff out. Makes sense to me.
