Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 03-18-2008, 05:59 PM
kapao818 kapao818 is offline
Mein Auto: E39 530i
E39 air horn removal
This is actually a continuation of Elvis530i 's DIY (thanks for your great DIY and pics on the DIY). i just added a few more pictures and I'm going to explain on how to get that 2nd clip loose.
this is elvis530's DIY. i followed his steps
http://www.bimmerfest.com/forums/sho...0&postcount=22
To get to the 2nd clip, you would have to remove the "L" shaped tube on the top of the airbox.
Then using the hole, you have to look inside and towards where the air horn is. You should be able to see the clip.
using a flat head-screw driver, you have to push clip towards the airhorn so it won't hook onto the airbox.
*the screwdriver head suppose to be on the other side but i wanted to show how the clip is
once both clips are loose, pull that sucker out. good luck.
Old 02-12-2013, 01:56 PM
yhorbachevskyy yhorbachevskyy is offline
Mein Auto: 1997 bmw 528I
so....... does this work?
