Old 08-01-2012, 10:44 AM
rh71 rh71 is offline
Among the Proud
Mein Auto: X5 3.0si
transmission sleeve (megatronic sleeve)
Anyone know how big a job it is for replacing this megatronic sleeve on an X5 specifically? They're saying it's leaking. I've seen posts about it in the 5-series forum and people there are saying it's simple to get to, so it's simple to change. Does the transmission need to be dropped in the X5's case? Any other complications etc.?
Also have a valve cover gasket that is leaking... is that also a simple job?
By simple I mean like a 1hr job on the clock.
'08 X5 3.0si - Alpine White / Saddle Brown interior
Specs: Sport Pkg, Premium Pkg, Tech Pkg, Comfort Access, Aero Kit, Style 433 staggered 20s on Conti DWS
Mods: Carbon 35 tint, LED angel eyes, GP Thunder 7500k fogs, H&R 20mm/25mm spacers, clear reflectors, gunsmoke-tinted taillights
Coded: Digital speedo, windows/sunroof/tailgate close via keyfob
X5 pics at Flickr
Old 08-02-2012, 05:53 PM
suthtow suthtow is offline
Mein Auto: tow truck
You need to drop the pan to replace the sleeve. Need to be extremely careful. Valve cover not to bad depending on what engine you have.
Sent from my C771 using Bimmer App
Old 08-03-2012, 02:12 PM
Among the Proud
Mein Auto: X5 3.0si
since you put it that way - do you suppose an independent garage who works on BMWs would be able to handle it? Is it a common job? Or should I stick with the dealer (despite their claim of long hours)?
X5 pics at Flickr
Old 08-03-2012, 04:48 PM
Go with a good Indy. You will get the same if not better service at a cheaper price.
Old 12-08-2014, 05:24 PM
TexasBMW's Avatar
TexasBMW TexasBMW is offline
Mein Auto: 08 X54.8 04X54.4 00E46CiC
I think I was just diagnosed with the same problem. Dealer list price is: $1094 for the sleeve work and $641 for the Oil Vac Pump...
2013 X5 5.0 Black 02/13
2008 X5 4.8 Space Gray/Tan/Dark Burl - Delivered 01.30.08
2004 X5 4.4 Silver. Acquired 02.12
2000 E46 Vert
2001 X5 4.4, Ret.
Old 12-08-2014, 06:18 PM
X5ist X5ist is offline
Mein Auto: X5
I did both myself, mechatronic sleeve and vacuum pump seal. The sleeve you need some time, maybe 2-3 hours, that's me. I did replace the transmission pan that includes the filter too. I flushed the fluid too. The parts you can order from Turner Motorsports. The oil about $22 per quart, I ordered 12 quarts, the pan $130 and the sleeve $22. Make a search on how to replace the mechatronic sleeve, you will find a bunch.
For the vacuum pump, if you go to the dealer they will replaced the whole pump, but you can just replace gaskets cost $22.
http://www.xoutpost.com/bmw-sav-foru...ump-seals.html
Very easy task. Hope all these will help.
2007 X5 4.8i Sports, Active Drive, Rear DVD, 7 Seaters
2011 Mini CooperS Countryman ALL4 Black
2013 Nissan Juke Nismo AWD
2011 Mini CooperS Countryman ALL4 Royal Grey
2007 MB ML63 AMG
2007 X5 4.8i Sports, Active Drive, Rear Entertainment
2007 Acura MDX SH AWD Elite Package
2008 Infiniti EX35 Journey iAWD
2003 Nissan Murano SE AWD
2003 Infiniti FX35 AWD Tech Package
2001 Subaru WRX
1999 Subaru Forester S
2003 Toyota Matrix XR AWD
Old 12-09-2014, 09:36 AM
Shiva Shiva is offline
Mein Auto: 2008 X5 3.0si
Valve cover gasket replacement on an in-line 6 cylinder engine is fairly an easy task. Only challenge is access to the bolts in the back-end of the cover. There are couple of video's on youtube.
Old 12-09-2014, 02:33 PM
TexasBMW's Avatar
That's a huge help. That link goes directly to just the X5 forums. Is there a better link out there?
How long will that gasket take to replace?
2000 E46 Vert
2001 X5 4.4, Ret.
Old 12-09-2014, 03:26 PM
Mein Auto: X5
Gaskets 30mins to 1 hr
2007 MB ML63 AMG
2001 Subaru WRX
