Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects or ask questions about how to fix something on your own. Help fellow Bimmerfest members improve your wrench turning skills! All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 08-01-2012, 02:44 PM
stephenking stephenking is offline
Mein Auto: 1995 318ti
ignition problems
just bought my first bmw 1995 318ti
the ignition harness needs to be replaced looks pretty simple the problem is this the two green wire harness the goes to the key switch is broken off the side of the ignition ring, also the key tumbler is shot just spins around needs to be replaced, i know the two green wires are part of a coded key system. my question is this can i get a harness and key tumbler Say with key from my local wrecking yard . is there any way to get the chip out of my old key to make this work. second question is the system going to be lock out because the green wires are ripped off the side of the key cylinder.and was tried to start without those wires being close to the key
Old 08-02-2012, 10:06 AM
can anyone out there tell me were i can get some help on this i would realy like toget this car running
