E34 (1989 - 1995)
Old 08-01-2012, 06:14 PM
Black Water Black Water is offline
Mein Auto: 1990 535i 3.5L Ger A/T
Upper trim piece rear doors interior
was the black piece at top of door (rear interior) glued on or just pressed on or what. I honestly can't tell what held it in place when new. The chrome trim at the very top of door panel or what?
Old 08-01-2012, 07:41 PM
goosefoot33's Avatar
goosefoot33 goosefoot33 is online now
Manualaholic
Mein Auto: 01 330Ci/94 530i
Not 100% sure what trim you're referring to, can you post a pic?
Sent from my Droid Incredible
Full 1995 530i Part-out! http://www.bimmerfest.com/forums/sho...d.php?t=568506
BMWCCA Member# 451235
(Summer) 2001 330Ci - ZSP
(Winter) 1994 530i "Greenie" - LOADED
Old 08-02-2012, 04:23 PM
This is it, rear driver side
Old 08-02-2012, 06:53 PM
Manualaholic
That is glued to the actual door card, and is supposed to stay connected to the door card when you remove it to access the inside of the door (i.e. for repairing or lubricating the window track).
To remove the door card, you push down on that part (after unscrewing the door lock "nub") and you will be disconnecting about 5 or 6 clips that hold the door card in place under the chrome trim.
It's kind of tough to explain without pictures. Search for "e34 door card/panel removal DIY" and you'll see some detailed pictures.
If yours has become separated, I recommend taking it off completely and applying liquid nails to the back, and reapplying. Just make sure it's lined up right
Old 08-02-2012, 06:58 PM
awesome. I thought it looked like they had been married at some point lol
Old 08-02-2012, 11:46 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
these days, its not uncommon for that part to have become unstuck, its caused by the same high interior heat conditions that causes the headlining to sag
