Expansion Tank leaking coolant on top. Can this be fixed?
My Radiator, Expansion Tank, water pump and thermostat have all been replaced in the last 11 months. Last night had a puddle of fluid under my car - and I've found out it's coming from my new expansion tank!
![]() The fluid appears to be leaking out of the top. Adjusting the mounting screw on top appears to make it worse until I opened up the cap and released the pressure. I'm pretty sure I've got a crack, but not certain. Does the screw possibly have anything to do with the leak? How far can / should I tighten it? See pic:
Partscontainer on ebay selles them cheap I will be buying one also soon
Is your expansion tank a Behr? Is it an OEM or delaer purchased? If not, you've probably bought an aftermarket or Chinese-made Behr. All of these commonly fail prematurely. Get the right part from the right source and you can forget about premature failures. Or try and save a few dollars and roll the dice...
I'm not nearly so worried anymore after looking at this DIY. Looks like a quick simple fix, though may be a little messy with coolant leaking.
This is one of the few things I think I can do myself. Thanks. http://www.bimmerboard.com/forums/posts/46816
Hi, Fudman:
My Replacement tank is a Behr - and the certified master mechanic at my local repair shop ripped me off to the tune of about $189 for it. Perhaps, not having the thermostat and water pump replaced right away played a role in having it bust so prematurely?
That screw is used for bleeding air out of the system. It should have an o-ring on it. Many companies sell it in brass because it is known to break.
ESS Tuning m60 version software m60 intake manifold a.f.e. c.a.i. 3" obx catback full powerflex urethane setup 545 ssk cdv delete m5 rear sway bar M5 chassis rods M5 3.15 lsd Bc-r coilovers w/ swift springs Akebono=suck ss braided brake lines coming soon: Jb lwfw
Topaz: hmmm.. When I loosen the screw, the coolant leak got worse? Is it possible it just wasn't tight enough? So far, I'm not seeing a crack, but it's hard to tell unless I remove it and take a good look.
The screw does not have to be terribly tight tho seal; some break it by tightening.
Did you replace the cap with the tank? It may not be holding pressure.
Ed in San Jose '97 540i 6 speed aspensilber over aubergine leather. Build date 3/97. Golden Gate Chapter BMW CCA Nr 62319. |
Replace the tank with BMW one. For 100 bucks it not worth the stress or risk to the engine.
Opening the screw allows air in and coolant out of the tank.
An e39 is like a beautiful wife, needs constant attention, lots of money, lets you down at the worse times but you’d never be without it. |
i never had the screw problem. I have only seen others report it. Like edjack said it doesnt need to be super tight. It has an o-ring. Check that the o-ring isnt damaged.
I didnt have a cap leak but i def had a cap wear out for some reason. http://forums.bimmerforums.com/forum....php?t=1777214
Tightening or loosening the screw when the engine is hot seemed to increase the flow of coolant leaking out. I don't think the screw is damaged - and the cap is certainly holding the pressure in. I think the thing is cracked somewhere up on top.
It's not worth the hassle - I'm going to replace it with a cheap, $45 unit and get rid of this car once and for all. I'm going to lease something new and not have to worry about car repairs anymore.
This is the canonical thread on the bleeder screws:
- Brass bleeder screws (1) (2) And this one on the new expansion tanks: - Why new made-in-China Behr/Hella expansion tanks are DOA (1) Lot's of good DIY information here: - Removal instructions for the alternator & drive belt system of a 2002 525i - Removal instructions for the fan shroud of a 2002 525i - Tools necessary for a cooling system overhaul
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 09-08-2012 at 10:22 PM. |
| Tags |
| expansion tank leak |
