Old 08-02-2012, 06:56 AM
Cvaria's Avatar
Cvaria Cvaria is offline
Mein Auto: 2003 Z4 ; 2002 Wrangler;
Question Replacing the rear console upper cover?
Has anyone replaced the rear console upper cover? Is there a write up or tools i need.
the storage compartment release button has broken and i'll need to replace it all. I tried gluing it but that didn't work.
I already ordered it but i have no idea how to go about replacing it.
It's part #2 in this picture:
http://www.trademotion.com/parts/200...agramCallOut=2
I like my 2003 Z4 2.5i... but love my smelly old 2002 Wrangler SE, 2013 Dyna Wide Glide 103 and evil 2007 HD Sportster 883/1200 conv!
Old 08-02-2012, 10:58 AM
thacket thacket is offline
Mein Auto: 2004 BMW Z4
Just had the same problem with my 2004. $58 for the cover and yes, the latch is just cheap plastic and mine broke as well. Someone on the forum told me it was a 10 minute fix and only 2 screws involved. it does look like a pretty simple fix!
Old 08-02-2012, 02:41 PM
Cvaria's Avatar
great, is there someway to merge the threads?
if i can't find anything, I'll do a write up.
Old 08-03-2012, 09:55 PM
SC2003Z4 SC2003Z4 is offline
Mein Auto: '03 Z4 2.5i Silver/Black
Hey guys, here is the info:
lower top, open console, remove two screws at bottom of cover, remove broken cover.
Remove any and all broken little pieces of plastic from old broken cover that may have fallen in.
When putting in the new cover be careful not to break any of the thin plastic legs....very delicate.
All together takes less than 10 mins.
Here is a picture of the 2 screws that hold it in place.
Javier 03 E85 2.5i
Old 08-04-2012, 01:43 AM
SD ///M4's Avatar
SD ///M4 SD ///M4 is offline
(prev. SD335is & SDZ4MR)
Mein Auto: 2016 M4 Coupe | 2006 Z4MR
Picture isn't showing up. Did you remember to change the properties to be visible to everyone?
- Tom
His: 2016 M4 Coupe | Sakhir Orange Metallic | Black Full Merino Leather | CF Trim | M DCT | Adaptive M Suspension | 19" Black Alloy Wheels | ZEC | ZLP | ZDB | MPE | ED 5/13/16
Hers: 2011 335is Couipe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11
Also His: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
Old 08-04-2012, 03:15 PM
oops
Javier 03 E85 2.5i
Old 08-09-2012, 05:56 PM
Cvaria's Avatar
Write-up
I went out and did the fix.
Two things:
  1. there are grommet like things holding the screws.
  2. be careful when removing the part. lifet slowly from the back.
guilty upper console to be removed
I opened the compartment door,
I removed the screws and grommets. (x)
button fell off
Pulled the cover off, from the back. had to raise top a little.
Placed the new cover, starting from the back. added grommets and screws.
Ran out and bought my girlfriend a funny running shirt to celebrate restored storage access in the USA
