Old 08-18-2012, 03:31 PM
CABimmerNation's Avatar
CABimmerNation CABimmerNation is offline
CABimmerNation
Mein Auto: 2010 750i M Sport
Beamload...It seems that everyone is wrong, you are right.
Carry on.
Dinan S3, PedalBox, 22" Agetro rims, H&R spt springs, RDsport front lip, coded, paddle shift retrofit, AlpineMSS HID 8000k. All exterior chrome, roof, roof spoiler and everything behind wheels painted black, wing, side and rear reflectors and door handle trim painted white, light smoke on tail lights. Audio: focal separates, earthquake low profile subs under front seats (crossed over as mid base to support the pathetic 4" fronts), arc audio amps, audiocontrol lcq-1 and epicenter, (2) L7 subs.
Old 08-18-2012, 05:26 PM
dunderhi's Avatar
dunderhi dunderhi is offline
Next: '18 AMG GT Roadster
Mein Auto: 15 M6 vert, 15 328dxt
Originally Posted by beamlord View Post
Stock m5 has been tested at 4.2 - 4.4, GRIP tests them here @ nordschleife first hand. Documented, approved by M rep.
Obviously even a simple tune can get this car down to under 4s, but that is NOT stock.
And you're forgetting the major weight difference on the s8 - deliberately?I won't even mention the torque trustability.
Sorry, no tune on the M5s, just measured U.S. spec M5 results as tested by Road & Track and Car and Driver. I guess you are claiming European M5's are slower.
As far as the S8. I had no issue with your claimed weight, so there was no reason to repeat that fact since all of you other data was wrong and needed to be corrected.
I'm not sure what you mean by your torque remark. Torque is measured and horsepower is derived from the torque measurement. If you don't believe the torque numbers, then the horsepower numbers are meaningless.
Sorry CABimmerNation, but I had to comment.
BMWs
2015 M6 Drophead Coupé
2015 328xd Estate
2013 X5M Sport Utility Vehicle
2013 650xi 2 Door Fastback Saloon
2011 Dinan 5 Saloon
2011 335d Saloon
Old 08-18-2012, 08:34 PM
Individual750LI's Avatar
Individual750LI Individual750LI is offline
BMW rocks!
Mein Auto: 2013 750I M
M5 does 4.2? Is that o-100km, or 62mph? What I have read from US mags are all under 4 sec to60.
2015 X6M, 2014 X1, 2015 Kia Sedona SX-Limited
Old 08-19-2012, 12:05 PM
landa220 landa220 is offline
Mein Auto: 2007 550i
Though it shouldn't matter as much since you've been recently "hammering it", but you should try the transmission program reset. I forget the exact sequence, but it's posted somewhere on this and other forums.
You should get a may get a more "perky" throttle and shift action since it will dump any slushy learned behavior. I'd at least try it.
2007 550i ordered 4/19/2006, delivered 6/16/2006: Black Sapphire Metallic, Auburn Leather, Anthracite Trim; Automatic, Navigation, Sport, Comfort Access, Premium Sound, Cold Weather, HUD, HD Radio, Sirius Radio, M-Tech Aero Kit! Don't forget the 50% tint, 19" Style 166 (M5) OEM wheels with Michelin PS2 tires.
Old 08-25-2012, 04:23 PM
Kjeronimo91 Kjeronimo91 is offline
Send a message via AIM to Kjeronimo91
Mein Auto: 2005 BMW 745LI
this why i exactly havent bought dinan . they claim 501 hp
our cars stock dyno 390-400hp to the wheels. somebody dyno there dinan and it only made 411 whp horsepower !!
velos in florida has manged to get 450whp tune only so remember DINAN ISNT ALL THAT
2011 550i zf Sophisto Grey/ Cinnamon brown sport pkg- Current
2008 335xi e92- 6mt alpine whte/Coral Rd JB3 18ohm sold
2005 745LI Alpine Whte / 5% all around tint / PDC /Sunshades/tinted tails/Built in Radar / 2- 12" w/ 2000w pioneer /Mtec angels sold
Old 07-19-2013, 09:17 AM
badblack550xi's Avatar
badblack550xi badblack550xi is offline
Chilling
Mein Auto: F10 2013 550i xdrive
Originally Posted by Richard109 View Post
Here is my review of the Dinan Stage 1 and Stage 2 upgrade on a 2012 750Li xDrive. Before having the Stage 1 installed, I wanted to establish some base line numbers in the qtr mile so I would have something to compare to. All passes were done in the Sport + mode, temperature 85* & approximately a half tank of gas.
Stock – 400HP, 450 lb-ft torque>>
I did 4 passes and the times were pretty consistent. My first run is slower because I let off the gas right before crossing the line, rookie mistake.
Stock
7/12/2012
#1#2#3#4
Reaction0.31370.58890.56640.399
60 FT2.27732.13852.10372.1656
330 FT6.00465.83575.79155.8694
1/8 ET9.01028.82548.77328.858
1/8 MPH83.3383.4483.6683.46
1000 ET11.552511.35311.292511.3853
1000 MPH97.1597.4297.7697.36
1/4 ET13.717313.477313.410613.5143
1/4 MPH99.91105.98106.26105.09
Stage 1 – 495 HP, 573 lb-ft torque>>
The car ran ever so slightly faster as you can see from the numbers. This was very disappointing to say the least. One would think that after adding 95 HP & 123 lb-ft. torque the car would do better than 2/10ths of a second faster in the ¼ mile. The car had about 1/8 less gas than when I did the "Stock" run, so I attributed the slight gain to having less gas. 60-80 lbs could account for this. Assuming something went wrong with the install, I took the car back to the dealer to have them check it out. Their computer said that the program was in fact installed correctly on the car and that they saw no problems. The dealer re-installed the program again to see if it made any difference. The dealer was still not sure of any significant difference. After some research we discovered that the x-drive cars may need to have Stage 2.
Stage 1
7/19/2012
#1#2#3#4
Reaction0.4670.33640.12830.1205
60 FT2.11372.09932.13042.0407
330 FT5.7945.75695.78035.6771
1/8 ET8.75628.70888.72558.6242
1/8 MPH84.384.5984.8184.73
1000 ET11.257911.211.212811.1125
1000 MPH98.398.7798.9298.79
1/4 ET13.36913.300413.310113.2117
1/4 MPH106.64107.24107.55107.32
Stage 2 – 501 HP, 580 lb-ft torque>>
When I went to pick up the car, I drove a stock 750Li x-drive car then immediately got into mine. I thought the car pulled much harder in 1st and 2nd gears. Before I went to the track I put 6 gallons of gas in it so the fuel level was the same as my first trip to the track. Again, as you can see the results are very disappointing. I really don't know what to think anymore.
Stage 2
8/2/2012
#1#2#3#4
Reaction0.21210.35930.30320.1679
60 FT2.21272.18692.1522.1316
330 FT5.86455.82395.79485.7597
1/8 ET8.82038.76848.73628.6993
1/8 MPH84.3384.8684.8984.89
1000 ET11.325211.25811.22411.1863
1000 MPH98.0699.1698.7798.79
1/4 ET13.438613.359713.320813.284
1/4 MPH106.58106.81107.6107.45
Hows that Dinan tune doing for you today ?
2013 F10 550ixdrive Carbon black metalic / BMS Stage 2 / AR Down Pipes/ 3" Custom Exhaust/ M5 mufflers and diffuser. WR 11.895 @118.69
Old 07-19-2013, 09:57 AM
ajdoha234 ajdoha234 is offline
Mein Auto: 2013 740Li
If my emory serves me right, his car was totaled and DINAN would not add the software to his new car..which is BS in my opinion. For 3500 bucks dinan should have some sort of tranfer guarantee? More like you pay a memebership fee and you are allowed to use the software on any BMW titled in your name.
Old 07-19-2013, 10:54 AM
Chilling
Wow that sucks weolcome to money hungry corp world =D
Old 07-19-2013, 01:49 PM
M4XBMW7's Avatar
M4XBMW7 M4XBMW7 is offline
TTurboFest
Mein Auto: F02 (750Li)
Richard is happily running the BMS N63 Stage 1
Old 07-19-2013, 04:16 PM
jgriffith007's Avatar
jgriffith007 jgriffith007 is offline
Mein Auto: 2009 750 Li
Re: 750Li xDrive vs. Stage 1 vs. Stage 2
Trying to explain or even be rational about spending $3000 and not being able to see the difference on paper is mind boggling to me. If Burger Tune is $350 and matches the numbers of Dinan, I'll order mine today. Looks like your only paying for the name.. At least at $350 for more "noticible" hp and torque seems to be a much better value. I don't track my car but I drive the **** out of it on the highway and I'm sure it will be noticeable either way if your happy with the feel though, more power to you!
Old 07-19-2013, 06:12 PM
PREDATOR 007's Avatar
PREDATOR 007 PREDATOR 007 is offline
Mein Auto: 2016 ///M5
Yeah, I was pretty disappointed when I called Dinan and told that my car was totaled and that I only had the software about 8 months. They said sorry about your luck, maybe you can shake down the dealer for a discount. Pretty shabby if you ask me. I wouldn’t give them another dime.
As Paul mentioned, I did purchase the Burger turner and it “feels” as good as my Dinan stage 2. After I get some miles on the car I will head to the track for some hard numbers. I plan on unplugging it and running 3-4 passes then plugging it in and doing another 3-4 passes. I’m looking forward to it.
** Removed ** 19,000th, 22,000th, 22,222th, 26,000th, 35,000th, 45,000th 48,000th, 63,000th, Honorary 87,000th and 93,000 post in delete pls
WR 12.50 @ 112.05 MPH 9/18/14
Old 07-19-2013, 08:48 PM
Yeah, I was pretty disappointed when I called Dinan and told that my car was totaled and that I only had the software about 8 months. They said sorry about your luck, maybe you can shake down the dealer for a discount. Pretty shabby if you ask me. I wouldn't give them another dime.
As Paul mentioned, I did purchase the Burger turner and it "feels" as good as my Dinan stage 2. After I get some miles on the car I will head to the track for some hard numbers. I plan on unplugging it and running 3-4 passes then plugging it in and doing another 3-4 passes. I'm looking forward to it.
Yes please let us know. Planning on ordering very soon... For $350, can't go wrong. Once my warranty is out, may download some serious work to mine. Upgraded turbos, intercooler, etc...
Old 07-20-2013, 03:59 AM
beamlord's Avatar
beamlord beamlord is offline
Wardaddy in retirement
Mein Auto: g11
Your new car is lci though so it's has already more hp stock, plus the mild tune - btw, I assume it's works fine on the TU engines? - makes it's most likely feel close to dinan tune on the old engine.
A buddy of mine wants the burger tune on his 2013 , we're looking for ways to order it from over here.
2016 G11 M-Sport Torque Monster, singapore grey, shadowline, ivory white / black, black alcantara.
Old 04-02-2015, 01:18 PM
750sfinest 750sfinest is offline
Mein Auto: 750li xdrive
Looking to order the N63 for my 750li tomorrow... looking for more info not trying to blow my baby up
2011 750Li xdrive
15% tint
22" Lexani
Straight pipe to MagnaFlow mufflers
Old 04-02-2015, 01:23 PM
M4XBMW7's Avatar
TTurboFest
Saw you message, got for it man best bung for the buck and safe .
Old 04-02-2015, 01:29 PM
Sounds good Thanks.. I just order my h&r lowering kit today. I'm gonna order the BMS tomorrow..next weeknd everything should be on. I'll post pics.
2011 750Li xdrive
15% tint
22" Lexani
Old 09-12-2015, 07:11 AM
abrams_doug abrams_doug is offline
Mein Auto:
Dinan Stage 1 for 2014 750LiX
I had been thinking about having the Dinan Stage 1 installed on my 2014 BMW 750LiX. I have read the comments and they are disturbing. I wondered if anybody had had a good experience with the Dinan Stage 1 upgrade on a 2014 750?
