Old 08-03-2012, 04:22 AM
GriffBrew GriffBrew is offline
Mein Auto: 06 M Roadster
Question M Roadster Service Interval
I know the schedule, I know what needs to be done and when. I know how to read the service indicator. But I have a question I didn't expect or find an answer to directly.
I just bought my 2006 M Roadster from CarMax. Great CarFax, it's been serviced regularly and was CPOed long ago. They (CarMax) told me they changed the oil. (I'm not sure they actually did and I don't trust it's synthetic if they did, but that's another story). The service indicator says it's due for an oil change in 2,600 miles.
I assume that IF CarMax had reset the service reminder, it would say 14xxx miles to next oil change. Correct? In other words, there's no way they set the indicator for 3,000 miles because they use regular oil, right? They can only reset the service indicator or not reset it. And resetting it would go to 15,000 miles. Right?
The real reason I'm concerned about this is that the car is at 60,xxx miles, so it SHOULD have had an Inspection II done not too long ago. If there is no way to mess with the indicator other than to replace it, it's very possible that the Inspection II was done around 48k miles, which would be about right (or a little early). This would also save me a bundle from doing Inspection II "just in case". [Edit] Looked at the CarFax again and it was at a BMW dealership at 50,xxx. Entry just says oil/filter, but could have been Inspection II. Maybe it was just oil but they screwed up the indicator so now it doesn't say Inspection II. I've read about that happening at dealers too.[/Edit]
I'm taking to a shop today to inspect. I'll ask them what they think of the engine sound with respect to the valves needing/not needing adjustment. I don't know what this car should sound like, so I can't say if it sounds proper.
I'm ready for some seriously spirited driving, but want to make sure she's ready for it!
Old 08-03-2012, 09:51 AM
SD ///M4's Avatar
SD ///M4 SD ///M4 is offline
(prev. SD335is & SDZ4MR)
Mein Auto: 2016 M4 Coupe | 2006 Z4MR
If you are on good terms with a local BMW dealer or know someone who works there you could ask them to run a Warranty Vehicle Inquiry on the VIN which will show the service history of the car. Even if you don't already have a relationship with a BMW dealer, offer to pay $25 or $50 for the report or convince them that you'll be bringing the car there for service.
- Tom
His: 2016 M4 Coupe | Sakhir Orange Metallic | Black Full Merino Leather | CF Trim | M DCT | Adaptive M Suspension | 19" Black Alloy Wheels | ZEC | ZLP | ZDB | MPE | ED 5/13/16
Hers: 2011 335is Couipe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11
Also His: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
Old 08-03-2012, 01:09 PM
chickdr chickdr is offline
Mein Auto: '06 M Roadster Imola/Blk
You also may be able to get the info from BMWUSA. I would give them a call. Any visit to a dealer should show up on a log with everything that was done.
