Darn Plastic Raidator
Found a leak
How long will this last? Just need to wait another 10k mi b4 I do the cooling overhaul.
03 530i
That crack looks pretty bad. You will never last 10K. Do the overhaul now or prepare to part your car out.
I wouldn't drive it. Next step is complete failure of the connection and all your coolant escaping, then big risk of cooking your engine.
Get a radiator ordered and installed, not worth the risk for the $150 cost of a radiator.
An e39 is like a beautiful wife, needs constant attention, lots of money, lets you down at the worse times but you’d never be without it. |
How long will it last?
Up until yesterday.
Do the whole 9 yards, not only the radiator. Check this and other forums about this.
Looking for a DIY? Parts? Check this out, it might be your ticket TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint Stable: e39 M54, e53 N62 & Tribby |
Sorry all. The pic is not that great in quality (dam phone). Its not a hole or crack but more like a micro pin hole. I didn't lose much water at all since it only sprayed a fine mist and only when hot. Cleaned the thing up and patched with LocWeld. We'll see how long it last. Keeping a daily eye on it. I figure ~15psi over an area less than the diameter of a hair should hold back with a patch area >300X its size. If it is a start of a fracture, then hopefully the patch will hold off complete failure for a little while longer.
I have half the parts for overhaul (WP, Pulleys, pump, tank.....). Guess I better tell the shop to order the radiator and the other hoses.
03 530i
That's a simple job to get your feet wet to DIY. And yes for sure get a radiator as well. 3-5hr for total overhaul for a first timer...
93 325iS 99 528iT |
There goes my coffee!
To the OP, to see why they told you to replace everything, look here: - Pictorial look at typical E39 cooling system failure modes (1) Then look here to figure out what to replace: - Complete cooling system overhaul recommended parts list (1) Otherwise, if you keep going with that leak, look here: - The tales of the most recent 50 people who ruined their E39 because of the cooling system overheating (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30) (31) (32) (33) (34) (35) (36) (37) (38) (39) (40) (41) (42) (43) (44) (45) (46) (47) (48) (49) (50)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 08-03-2012 at 08:18 PM. |
Hmmmmmm.... it took me about 3 days (elapsed time).
But, I took a thousand pictures, and, well, I broke a few things ... ![]() - How not to remove the nipple from the E39 radiator (broken radiator nipple) - How not to put your E39 fan clutch back on (crooked fan clutch nut) - How not to bleed your E39 cooling system (1) (broken bleeder screw) - How not to replace your E39 thermostat (thermostat loom misplaced) - How not to remove your E39 expansion tank (broken expansion tank nipple & cn90 repair) - etc.
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
Holy crap. 3 days. Jesus.
93 325iS 99 528iT |
To the OP, there is no need to rack your brain on reading other peoples' cooling system problems. Please save yourself the headache of any highly probable further cooling system damage and have the system overhauled. All the reading in the world will not benefit your car. Just take the immediate action and get it done. Goodluck and enjoy your car.
I'm slow. But methodical!
![]() By way of example, here are the removal instructions for just the shroud! ![]() Quote:
How long will it last?on plastic that is already deteriorated...hmm, at least 2days before the day after tomorrow.
![]() Sent from my MB855 using Bimmer App |
This is subjective ... but I'd say yes and no to that statement.
First off, it's true that reading, in and of itself, doesn't overhaul his cooling system. Yet, the OP seems, based purely on the slight intimation in his initial textual remarks, to be thinking he can 'limp' along with that leak in his cooling system. That I wasn't the only one who inferred what the OP seems to have implied is inherent in the combined responses by others above. So, if the OP is inclined to follow advice given to him by people he doesn't know, then he already has all the advice he needs, as nobody who knows the E39 would even think of NOT overhauling that cooling system pronto. However, if the OP's Myers-Briggs personality is such that he forms his own opinions based on numerous datapoints (which, by the way, is what I do), then all the reading in the world will help him make a better decision! Note: See Bimmerfest posters' personality profiles! To that end, we've provided the OP with a bit of select reading; but, if he were to be serious about it, he would read the following (which most of us have read every single post of): - What to look for when your KTMP (1) or coolant temperature gauge indicates overheating (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) & what to look for in a perfectly normal E39 cooling system (1) & a picture of every failed part in the cooling system (1) & various techniques to properly bleed (1) (2) (3) & refill (1) & drain (1) (2) & flush (1) & what coolant to use (1) & what parts to replace (1) (2) & how to retrofit brass bleeder screws (1) (2) & what special tools to make or buy (1) & how to tell how old your cooling system is (1) (2) & how to test the cooling system auxiliary electrical fan (1) (2) (3) (4) & a DIY for replacing the auxilliary fan (1) (2) (3) & the infamous fuse 75 (1) & the aux fan relay (1) & how to diagnose lack of HVAC/IHKA heater core heat with cooling system (auxiliary pump) at idle (1) & a Behr radiator and Behr/Heat expansion tank autopsy (1) (2) & request for another Behr surge tank autopsy (1) & why new made-in-China Behr/Hella expansion tanks are DOA (1) & E39 Fan shroud removal DIY (Besian) (M54) & some of the better cooling system DIYs (cn90 1997-1998 M54TU) (cn90 V8) (aioros '99-03 M54) (Ĺgent99 '01 530i) (pelican 3-series) (bluebee M54B25) & tricks to replace the fan clutch nut (1) & lower-hose thermoswitch o-ring (1) & to non-destructively remove the heater hoses (1) or radiator nipple (1) or expansion tank nipple (1) (2) or Oetiker clamp (1) or misplaced thermostat wiring loom (1) or broken bleeder screw (1) & modifying the cooling system pressure cap (1), or using propanol-based zero-pressure fluids like NPG+ (1) (2) (3) (4) (5) or all-aluminum cooling system parts by Zionsville (1) (2) (3) aluminum radiators & what happens if you drive one mile too far with an overheated BMW cooling system (1). In summary, most of us have read all of those posts, and therefore, we can make a good decision. The OP hasn't yet established that he's convinced of the advice above. That's OK. Luckily I stopped counting the blown engines at number 50 ... so he's safe! ![]()
What people are trying to say is that total failure of the cooling system is usually very sudden.
Perhaps you will get lucky and it will break in your driveway but if the thing goes and dumps all of the coolant in a matter of minutes when you're in traffic or on the motorway, you're screwed. I actually saw something similar happen to a 1990's Z3 the other day, a huge plume of white smoke/vapour from the engine bay when the thing was stuck in traffic. He had no way of getting to the side of the road. Don't know how lucky you feel but I would very much doubt it would last 10k miles. |
Don't forget, the M54 doesn't not respond well to overheating. Do the overhaul before you toast your engine.
"Some things around here don't respond well to bullets"
GROUND the car immediately and start researching "cooing overhaul".
Or you will regret soon. |
If you don't have budget for a cooling overhaul, then at the minimum, do the radiator first.
(But doing it piecemeal like this will cost you coolant as every time you open the system, you lose coolant!). Just skip a few beers and dinners, you will have money for a new rad. On the issue of brand, there is a debate here between Behr vs Nissens. I have had good luck with Nissens, now 6 years zero issues. |
Well the patch lasted this whole time. Thought it would be 10k by now but only did 8k. There was a new micro leak between the core and tank the other day and since there is time during the Xmas week, decided to do the cooling overhaul and OFH gasket.
Did the job as what the guys in the shop recommended. Went with Nissen but found it was not an exact fit. Fits but there was a little tight around the shroud. I personally recommend to others reading this thread to address the problem properly, just as everyone else has mentioned here. Do the complete job. Not patch and pray. When there are signs that the cooling is failing, replace all plastic and rubber parts. Even if it was not bad now it will likely fail just after you stress it putting it back together.
03 530i
I'm actually driving my boring camry more until I get this done. I have parts ordered from different sites online.The only parts I haven't seen before on recommended on any lists are: Expansion Tank Hose 11531438632 ~30$ Expansion Tank Hose 11531438633 ~23$ Coolant Hose 11531438634 ~26$ These are on your parts list on the link. I guess I will order those too. All I have seen up to now is the upper and lower hoses. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
