Old 08-08-2012, 09:16 AM
STIHLBOLTS STIHLBOLTS is offline
Hat's On, Tops Down!
Mein Auto: 2013 335is
There is nothing in my glove box. The Aux input is under the dash just above the ashtray. It is in that rectangle plate. The dealer did not charge me for anything, it was part of the purchase deal that they install it. But like I said earlier I was under the impression they would take out the cig lighter and put it there, but when I picked up the car and did not see it I got upset with them until they pointed out it was under the dash hidden from direct view. I'll post a picture tonight. According to Fedex and USPS, my cable and clip should be here tomorrow. Once I get it installed I will post a picture.
2013 335is Convertible
MODS:M3 Strut Brace / Smart Top Module / Ikon Lip and spoiler
VRSF Charge Pipe /
BMWCCA Member
Previous: 2004 3.0 Z / 2008 Z4M
Old 08-08-2012, 02:40 PM
chickdr chickdr is offline
Mein Auto: '06 M Roadster Imola/Blk
I knew you didn't have a glovebox connection, but now I get it. I suspect it was there all along and the dealer just wasn't aware of it until they looked. It is very hard to see(really impossible without either feeling it, or craning your head down to look under the panel). The SpecDoc is really the cleanest install for the iPhone. Just $$$$.
Old 08-08-2012, 05:31 PM
The plug came in today, as you can see the USB goes to power and the MP3 goes under the dash. I had to use the phone to take the picture, but you get the idea. The bracket will go to the right of the A/C control. The cords are just the right length for the Iphone position. No I won't have any steering wheel or monitor control over the Iphone other than volume. But its right there and close at hand, less a whole lot of clutter.
VRSF Charge Pipe /
BMWCCA Member
Old 08-08-2012, 06:52 PM
Droptop85 Droptop85 is offline
Mein Auto: 03 Z4 3.0i
Originally Posted by Cvaria View Post
use this $30 oem part and mount it in your ashtray or wherever else.
It is designed for the 3 series but works in the z4
http://www.amazon.com/BMW-Genuine-Auxiliary-Audio-Series/dp/B000PA00XM
Ordered the 30.00 aux input today. Came to 40 with shipping. I'll keep everyone updated
Old 08-08-2012, 07:50 PM
GriffBrew GriffBrew is offline
Mein Auto: 06 M Roadster
I just installed mine today. Very easy and completely straightforward. Pull out the vents, pull out the stereo plug it in and go!
One hiccup for me was the plug on the radio. There is a big, rotating piece that holds all the plugs in to the radio. You have to tilt that back and unplug from the radio. Then I slipped the connector into that piece and put it back together. At first, I didn't understand this and thought I had the wrong part.
I used Amazon, but bought one labelled for the X3/X5 http://www.amazon.com/BMW-Genuine-Au.../dp/B000PA03AC This worked fine on my 2006 Z4MR w/o CD Changer. I think I selected it because I could get it with Prime (I can't remember what I did two days ago).
Oh, one other hiccup. I wanted the install plate that came with the plug to be installed on the outside. I drilled holes for it and put it together, but found that the plug wasn't seated right so I could only get on channel from my headphone jack. I removed the plate (for now) and just have the 3.5mm jack there. It works fine, but I'm frustrated I have two drill holes for the screws that hold the plate in place. I need to countersink the plug a little to get the plate to seat correctly. I assume the install location in the X3/X5 is thinner than this panel we are all mounting to in the Z4. No big deal, I just didn't want to spend the extra time today and I plan to add a cigarette plug there for additional power so I'll already be taking it apart again.
Old 08-09-2012, 06:57 AM
You can always get a new cover plate, they are only $13 from BMW.
VRSF Charge Pipe /
BMWCCA Member
Old 08-09-2012, 07:04 AM
And you can order the 2007 and up version which includes the aux port name plate already installed!
Old 08-09-2012, 07:24 AM
VRSF Charge Pipe /
BMWCCA Member
Old 08-09-2012, 03:39 PM
jcutrell jcutrell is offline
Mein Auto: 2003 BMW Z4
I just used a small grinder to remove some of the plastic from inside of the cover plate (where it wouldn't be seen). It worked fine.
Old 08-09-2012, 10:04 PM
Psygnosis Psygnosis is offline
Mein Auto: 2004 Z4 3.0i Sport
I left the plate off the jack when I installed mine, the jack screws together and that holds it in place.
I've heard that you might not be able to get the old panel from BMW anymore. They may only have the 2007/2008 part now, the one with the cut out for the AUX
Old 08-09-2012, 10:29 PM
WestCDA WestCDA is offline
Mein Auto: 2006 Z4 3.0si
That does seem to be the case - I ordered the original (no cutout) panel for my 2006 so I could experiment with installing a homelink module, and was shipped the one for the later cars with the aux plug cutout in it.
I ended up modifying my original for the homelink install, and also recently added an aux jack to it as well. No 'AUX IN' name plate - you can't see it under there anyway. I just drilled a hole, stuck the jack through and screwed on the outer ring.
Old 08-11-2012, 01:17 PM
I got everything installed. Wedge the top of the clip in, push the bottom part down to grab the seam and it snaps in place with the help of a little bit of double stick tape. The holder comes in several varieties, I choose the non powered one because of the Y cable. So if you find you already have the MP3 Plug under the dash this is the simplest solutions IMHO.
Love it.
Many thanks to Skipkiller and BruceJ for the assistance.
Items Used:
1. BMW USB Power plug - Tishner $19.95
2. Y Plug - http://www.ebay.com/itm/400218936351...84.m1497.l2649 $13.89 + shipping
3. ProClip USA - Clip and Non-Powered holder. $70.00 + shipping
VRSF Charge Pipe /
BMWCCA Member
Old 08-11-2012, 01:24 PM
Thanks for the pics! That's exactly what I'm going to do now. I have a dual USB charger in the mail already. I also have a aux/USB cable that's been sitting in my house. Paid 2.97 for the cigarette charger, 7 for the USB/aux cable, and 40 for the aux kit on amazon.
Old 08-13-2012, 04:35 PM
My aux input came in today! ..and I'm pretty sure it's the wrong part. Here are a few pics. The part says its for a e46 3 series..
Photobucket Pictures, Images and Photos
Old 08-13-2012, 05:59 PM
It should fit into the large plug that was in your stereo. It fits into the bottom-right of that plug. Then, the whole plug goes back into the stereo. Mine was for 5-series/X5, but it fit and works great. The plugs all look the same to me on the Amazon photos. http://www.amazon.com/gp/product/B00...ls_o00_s02_i00
Old 08-13-2012, 08:21 PM
bten's Avatar
bten bten is offline
Luv'in Texas
Mein Auto: '08 Z4 3.0si
+1
Check the Main plug that is held in with a lever on the back of the radio. the Aux in cable plugs into the back of the Main plug (you plug it into the plug)
2008 Space Gray Z4 3.0 si, Saddle Leather interior (to haul A$$)
2011 Nissan Frontier King Cab (to haul crap)
2010 Lexus RX350 (to haul people)
2009 Club Car Precedent (to putter around the beach)
Old 08-13-2012, 09:50 PM
There is six prongs on the bottom right of the stereo and 5 holes on the connector. Is that right?
Old 08-13-2012, 09:51 PM
Mine is for the e46 3 series but was said to be universal for the z4. But I just couldn't seem to get it to fit correctly
Old 08-14-2012, 07:54 AM
Cvaria's Avatar
Cvaria Cvaria is offline
Mein Auto: 2003 Z4 ; 2002 Wrangler;
trust us... it's the right part. (http://www.bimmernav.com/store/catal...-item-156.html)
you must use the stock harness
install threads: http://www.bimmerfest.com/forums/sho...=180804&page=1
I like my 2003 Z4 2.5i... but love my smelly old 2002 Wrangler SE, 2013 Dyna Wide Glide 103 and evil 2007 HD Sportster 883/1200 conv!
Old 08-14-2012, 11:38 AM
The connection on the back of the radio is a 12 pin connector. The aux harness is a 10 pin connector. I think they shipped the wrong part?
Old 08-14-2012, 11:53 AM
Nv! I'm going to make it work. Thanks for the help everyone!!
Old 08-14-2012, 12:49 PM
Got it! I removed the grey cover on the aux cable and revealed the smaller black connector that allowed it to fit behind the stereo. Here are some pics so future installers can see where exactly the 3 wires need to be. And then the final product.
Removed grey cover
Placed connector bottom right of stereo one pin to the left (hard to see)
Ran cable down
Installed aux input in bottom cover.
And tada!
Works like a charm. Sounds perfect.
Old 08-15-2012, 05:23 AM
Excellent! Mine didn't have that grey cover. Thanks for pics, that will definitely help others in the future. I regret not taking photos as I went.
Old 08-15-2012, 08:17 AM
Cvaria's Avatar
and you saved $!!
Old 08-03-2013, 08:47 AM
cuttermd cuttermd is offline
Mein Auto: 2003 Z4 3.0i
New Z owner, just installed the aux input
Thanks for posting the pics for getting this to work by removing the grey cover. I had the same kit for (E46) & you saved me alot of time on the install.
