99 e39 Cranks but or spark. please Help. - Bimmerfest - BMW Forums
Old 03-26-2013, 12:26 AM
manzoorz5001 manzoorz5001 is offline
Mein Auto: 1999 BMW 528i
Hello,
my 1999 bmw 528i, is not starting. The car cranks but no spark.
I'm the following errors:
DME:
209: manipulation protection error
69: avtivate Relay Fuel Pump
130: Signal CAN ASC 1
50: Avtivate Solenoid Valve fuel circulation switch
35: avtivate Relay Secondary air pump
126: avtivate Solenoid valve tank-leck-diagnostic-pump
EWS:
15:Power on reset
16:Key number 1 not valid because of wrong identification
0: Key number 0 not valid because of wrong identification
1: Key number 0 not valid because of wrong password
Can someone please provide me with information on what I shall do to get the car started.
thanks in advance
Old 03-26-2013, 03:56 AM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Looks like your key isn't being identified by the EWS, however that should prevent the starter from engaging.
Are these new or old codes? If old, clear them out and see which ones come back.
Have you checked the fuses in the DME box?
2000 540/6 Slightly tweeked...everywhere
Old 03-26-2013, 09:03 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
How long has this been going on? Do you have fuel pressure? There may be an EWS failure. It may also be a defective ring antenna around the ignition switch, which has been known to fail.
Old 03-26-2013, 12:24 PM
i cleared the codes from ews and brummmm. car started and all the errors from the engine are gone as well.
thank you soo much.
