Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 08-04-2012, 02:14 PM
jotscan jotscan is offline
Mein Auto: 2003 530i
DIY - BMW 2003 530i E39 Electrical Power System Maintenance
Experimenting with an electrical monitoring unit and battery charging system to avoid a repeat of being stranded due to a dead battery or defective alternator.
Monitoring unit: BatteryMole
Charging unit: Save A Battery
Charging monitoring unit: AstroFlight Whattmeter
Monitoring Unit – BatteryMole:
Charging Unit - Save A Battery:
Charging monitoring unit - AstroFlight Whattmeter:
Car hook up:
The BatteryMole provides an alarm if there is something wrong with the charging and battery system. The charging unit’s performance is monitored by the AstroFlight metering unit. After the charging unit is disconnected from the AC source, the DC voltage reading on all three displays, BatteryMole, Save A Battery & AstroFlight must be the same.
ID:	335464   Click image for larger version
Name:	Save A Battery.jpg
ID:	335465   Click image for larger version
ID:	335466   Click image for larger version
Name:	Vehicle Hook Up.jpg
File Type: pdf DIY - BMW 2003 530i Electrical Power System Maintenance.pdf (271.0 KB, 45 views)
astroflight whattmeter, battery, batterymole, charging, save a battery
