E36 (1991 - 1999)
Old 09-12-2012, 01:58 PM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
bimmerfest Supporting Member
Mein Auto: 1996 328i
oof, this is quite the frustrating issue. Maybe someone else can shed some light. all i know is that if pinching the return worked that means fuel backed up and had enough to feed the injectors
insert witty signature quote
Old 09-12-2012, 02:04 PM
cj.surr's Avatar
cj.surr cj.surr is online now
some kid
Mein Auto: 1995 318is
All you need to solve this problem is an extra pair of vice grips...
-CJ
Old 09-12-2012, 02:25 PM
FenderBender's Avatar
FenderBender FenderBender is online now
Needs Boost
Mein Auto: Red Sled
Went back to the garage update coming.
Cj, don't think it didn't cross my mind...lol.
Turbo Build Here
Parting Out Complete 96 328is
Old 09-12-2012, 02:35 PM
Needs Boost
Mein Auto: Red Sled
Turbo Build Here
Old 09-12-2012, 02:37 PM
Kdoherty's Avatar
what the crap. lol. coolant leak..... tehehe. hopefully it holds out on the test drive. if not. pluck the engine and swap in a giant hamster ball
Old 09-12-2012, 02:41 PM
Needs Boost
Mein Auto: Red Sled
Idk what's up, but it idles just fine! Granted it doesn't have an air filter so it's all not quite together and perfect yet.
Probably won't drive it tonight, need that filter and need to bolt some things back up, oil change too.
Turbo Build Here
Old 09-12-2012, 02:50 PM
Needs Boost
Mein Auto: Red Sled
I think possibly the FPR was "stuck" all I did was unplug and re plug the vacuum line from it.
Turbo Build Here
Old 09-12-2012, 06:56 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
my head hurts from reading all of that...
matt,
there s/b 2 pumps on this thing. 1 in the tank, 1 on the fuel line. the in tank unit is a sending (feeder) pump, while the inline pump is the one that builds the higher pressure.
iirc there are mods to convert to a single pump, but that is neither here nor there. at least not now...
take your fuel pressure readings. if you are not running without the return line being pinched off, then i say fuel delivery is an issue. your pump may be running, but it may not be building enough pressure to allow the vehicle to run properly.
the fpr uses vacuum pressure to reduce the fuel pressure, and when accelerating hard, the vac drops and fuel pressure increases because the diaphram inside closes.
on average, the fuel pressure should increase about 10 psi when the throttle is snapped.
this is how you can check for fpr operation.
so i suggest checking fuel pressure and fuel pump operation. the in tank pump.
df
Old 09-13-2012, 04:25 PM
Poorboysracing's Avatar
Poorboysracing Poorboysracing is offline
I <3 Underpowered BMW's
Send a message via AIM to Poorboysracing
Mein Auto: '00 BMW 528i '68 BMW 1600
my e30 had dual pumps aswell, i initally though that was one of its issues Sadly it wasnt for me. good luck matt!
*The I Drove to Both East and West Coast Bimmerfest Club* Member #1
Old 09-13-2012, 05:04 PM
Needs Boost
Mein Auto: Red Sled
What was your issue Joe?
Df, how do I check the in take pump? It has to be working because a ton of fuel is flowing out, correct? I can also hear the in line pump working.
Scratch the whole "I fixed it" part. Still not quite right, going to get a fuel filter air filter and oil filter tomorrow. Install, test fuel pressure, and report back.
Turbo Build Here
Old 09-13-2012, 05:18 PM
if both pumps arent pumping, then the fuel pressure will be low and slow. like lola...
as for how to make sure the supply pump in the tank is working, unplug the inline pump and read the pressure.
not sure if there is a spec for that pump or not, though. never owned an e30.
df
Old 09-13-2012, 05:21 PM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i Hellrot Red
This thread makes me Want to never own an E30...
Patrick ///98 328i hellrot///BMWCCA#465139
Old 09-13-2012, 05:24 PM
never understood the reasoning behind 2 pumps...but i believe there is a retrofit to a single pump.
df
Old 09-13-2012, 06:04 PM
Needs Boost
Mein Auto: Red Sled
Will do! Thanks Df.
Sent from my ADR6400L using Bimmer App
Turbo Build Here
Old 09-14-2012, 05:33 PM
Needs Boost
Mein Auto: Red Sled
Did the air filter and fuel filter, really no change. I forgot the fuel pressure gauge, DOH! Stupid me.
FWIW, I could not blow through the old fuel filter, however I could the new one.
Turbo Build Here
Old 09-14-2012, 05:36 PM
Kdoherty's Avatar
hmmmmmmm. I bet you can't wait to get it running so you can sell it
Old 09-14-2012, 05:40 PM
Needs Boost
Mein Auto: Red Sled
Lol MAYBE!
Turbo Build Here
Old 09-18-2012, 03:08 PM
Needs Boost
Mein Auto: Red Sled
Alright, real fuel pressure updates, sorry for the videos, some are quite long.
To sum, fuel pressure engine off in spec, maybe a hair under.
Fuel pressure engine on, 30 or so psi, spec is 43psi or so.
Turbo Build Here
Old 09-18-2012, 05:45 PM
Needs Boost
Mein Auto: Red Sled
Cricket cricket......
Turbo Build Here
Old 09-18-2012, 06:32 PM
that's only about 75% of spec, so that could give you issues.
what does the reading do when you remove the vacuum to the fpr?? if it goes up, by how much??
if it doesn;t go up, then i would look at the price of pumps, and possibly the retrofit idea.
replacing 2 pumps to me is such a silly idea. but that's me.
i tend to like simple and clean.
df
Old 09-18-2012, 08:07 PM
Needs Boost
Mein Auto: Red Sled
I think in the one video I removed the vacuum line and the pressure did go up. What does that mean?
Turbo Build Here
Old 09-18-2012, 08:53 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Means your fpr is working. It reads the removed vacuum line as a drop in vacuum which means open throttle. At open throttle you want more pressure to feed the injectors since the fuel demand goes up.
Sent from my MB860 using Bimmer App
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 09-19-2012, 04:19 AM
Needs Boost
Mein Auto: Red Sled
I guess I will test each fuel pump tonight and go from there!
Turbo Build Here
Old 09-19-2012, 08:03 AM
nothing.
Mein Auto: ItAintUrShtYUCare?
Ill be honest now. lately i have been wanting to buy a e30 and slam it and put some wide wheels on it.
would be my little truck.
nothing.
Old 09-19-2012, 09:12 AM
Needs Boost
Mein Auto: Red Sled
Lol you hate them!
Turbo Build Here
:3
