E36 (1991 - 1999)
Old 10-04-2012, 07:03 PM
drivinfaster's Avatar
bimmerfest Supporting Member
Mein Auto: rescued bmw's
in some cases yes. when i hear the motor sounding like that, the first thing i want to check is valve lash.
do it cold and it's much easier.
and disregard the coathanger tip. that's for the m20's.
df
Old 10-04-2012, 07:10 PM
FenderBender's Avatar
FenderBender FenderBender is online now
Needs Boost
Mein Auto: Red Sled
Will do, I'm off work tomorrow so I should be able to get some stuff done.
Thanks df!
Sent from my ADR6400L using Bimmer App
Turbo Build Here
Parting Out Complete 96 328is
Old 10-04-2012, 07:43 PM
C14 Rider's Avatar
C14 Rider C14 Rider is offline
Mike
Mein Auto: 1999 328is 2010 Audi S4
Did I see somewhere in these eight pages of fun you were looking for seats ??
not sure if a vert seat would work or not..
http://binghamton.craigslist.org/pts/3291771078.html
1999 BMW 328is/M Sport Package/5 speed/122k and climbing/
2010 Audi S4 Premium Plus/3.0L Supercharged V6/Quattro/6 speed/25k and climbing/
Old 10-04-2012, 08:58 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
To bump the engine over while setting the valve lash, jumper from #1 pin to #11 pin.
Name:	diagnostic connector 84 318i.jpg
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 10-05-2012, 05:17 AM
Needs Boost
Mein Auto: Red Sled
I actually got some front
And rears just the other day.
Thanks Ken!
Turbo Build Here
Old 10-05-2012, 04:11 PM
Needs Boost
Mein Auto: Red Sled
Alrighty, first valve adjustment ever. Went smooth, wasn't too hard at all actually. The BMW eccentric key adjustment is slick. The hard part was knowing how "snug" is "snug" on the .008 feeler gauge.
However, she is all quiet now, no rattling.
As far as everything else, same issues. It went back to it's old ways by not staying running, and wouldn't start after it was running for a while. Also couldn't really give it throttle like usual. I even pinched the return line to build a hair more fuel pressure and it still died just the same.
I unplugged the ECU and it still built fuel pressure and turned over, almost like when it doesn't want to start the ECU isn't working. Thoughts? Also, the second coolant temp sensor next to the one I replaced had no resistance when I measured it with my multimeter, don't know if there is a spec or not though.
Turbo Build Here
Old 10-05-2012, 06:27 PM
matt, so the m10 also uses the round adjustment cam on the rocker?? (never did an m10 adjustment, just the m20, but it makes sense they use the same set up)
when i googled for images all that came up were threaded style with a jamb nut. i used a piece of wire hanger with slightly bent ends to fit the hole in the eccentric.
anyway, what setting did you have your dvom set on?? if you were on the wrong setting you would not get an accurate reading.
there should be a resistance, though.
df
Old 10-05-2012, 07:22 PM
Needs Boost
Mein Auto: Red Sled
Yessir easy!
I had the meter the same as when I checked the other sensor.
What would you do next?
Turbo Build Here
Old 10-05-2012, 07:30 PM
what i would do next is grab a sammich....
srsly...with pickles.
ok. what do you mean '2nd' coolant sensor??
will this other sensorthat you replaced fit the plug of this sensor with no resistance?? if so, swap them out and see what happens. if the plug is different, then i would make a jumper lead to connect the harness to the sensor (and leave it plugged in, uninstalled to the engine, just secure it so it doesn't move around)
unless i misunderstood you. then add spicy brown mustard to the sammich...
df
Old 10-05-2012, 07:34 PM
Needs Boost
Mein Auto: Red Sled
I can swap sensor wires, it makes no difference.
Confused
Turbo Build Here
Old 10-05-2012, 08:31 PM
wait, maybe i am confused. you have 2 sensors, and replaced 1?? just plug the one you removed into the harness where the sensor that shows no resistance is. if it's sending the wrong voltage, the dme may think it's supposed to be in closed loop and is leaning out the engine.
df
Old 10-05-2012, 08:35 PM
Needs Boost
Mein Auto: Red Sled
I did that, no change. How do I check to see if there is a messed up wire?
Turbo Build Here
Old 10-05-2012, 08:56 PM
i would verify the voltage with your dvom. there should be a spec for the wire as it is a potentiometer. it should change the voltage through the sensor back to the dme.
you can backprobe the sensor wiring to see tha voltage back to the dme, and verify the same voltage @ the dme connector.
you will need to get a schematic. you may be able to find it under the 'wedophones' inthe stickies at the top.
i would round up the usual suspects, crank sensor, afm, coolant, tps, and o2. i'd also look through and see what sorts of things were found to be related in other m10 issues.
without seeing the charging system performance, battery condition and state of charge, and the gasses coming out of the tailpipe, i'm down to logical suspects. this is the sort of diagnostic routine that takes a lot of time, research for specs, and verification of components.
df
Old 10-05-2012, 09:27 PM
Needs Boost
Mein Auto: Red Sled
I have a case of beer in the fridge and taco meat made, what else do you need to come help me in person?
Turbo Build Here
Old 10-05-2012, 10:19 PM
an invitation....
actually i believe that you are about 4 hours away from me. i'm about 40 mins se of philly.
about 1/2way between philly & ac.
not sure if i could really swing it with the current work schedule, tho. i won't have time until november at the earliest.
df
Old 10-06-2012, 05:22 AM
Needs Boost
Mein Auto: Red Sled
Well I'll keep fiddling with it and see what happens until then lol. If you did by change want to come I would definitely give you gas money at least.
Turbo Build Here
Old 10-06-2012, 02:59 PM
Needs Boost
Mein Auto: Red Sled
I'm not sure how much of a difference it would make, but my charging system isn't up to snuff. Check out the vids.
How would all that effect how it runs?
Turbo Build Here
Old 10-06-2012, 05:37 PM
can't see the vids, but yes...the whole system runs off voltages. if the charging system is wonky then the rest of the performance can suffer as well.
df
Old 10-06-2012, 05:56 PM
Needs Boost
Mein Auto: Red Sled
Sorry Df, here they are:
Turbo Build Here
Old 10-06-2012, 06:33 PM
yeah matt, that's pretty low...does it run any different when hooked up to the charger??
df
Old 10-06-2012, 06:47 PM
Needs Boost
Mein Auto: Red Sled
I think it idles better, I have to do more testing. I think this might explain why it won't start after a while, not enough current
Turbo Build Here
Old 10-06-2012, 06:49 PM
y'know,...if we keep this up, we'll have to rename this the matt & df thread....
kinda makes me feel like everyone is watching me...
df
Old 10-06-2012, 06:53 PM
Needs Boost
Mein Auto: Red Sled
Haha, have to do an alternator test. Just check voltage coming off of it?
Turbo Build Here
Old 10-06-2012, 07:44 PM
well it's definately *not* charging, but the question is why.
voltage regulator shot??
fuse/fusible link blown??
i'd check for power to the alternator first, and then, if there is power there i would check on how to test the regulator. i do believe they may be serviceable, but not absolutely positive.
i'd search that little bit of info on how to check the voltage regulator. i know (knew) how to do it on chrysler products (and some others) back inthe day, but that's been long forgotten info...
df
Old 10-07-2012, 02:31 PM
Needs Boost
Mein Auto: Red Sled
I read that the if the regulator is less than 5mm to replace it.
Here is mine:
Now, can I get the alternator tested without the regulator? If I can, I'll go ahead and order a regulator.
However I don't want to order one if the alternator is bad because I new alternator may come with a regulator.
PS, what is that wire on the back of alternator?
Turbo Build Here
:3
