E36 (1991 - 1999)
Old 10-07-2012, 05:49 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
ground wire and capacitor??
i'd put the regulator back on and truck the unit to a parts place that tests them. you can test an alternator with a faulty regulator, but not sure about testing one without it.
df
Old 10-07-2012, 06:41 PM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
Cool, will do tomorrow, thanks!
Sent from my ADR6400L using Bimmer App
Turbo Build Here
Old 10-08-2012, 02:04 PM
Needs Boost
Mein Auto: Red Sled
Advance "tested" the alternator, but they definitely didn't know what they were doing. I ended up ordering one anyway from them, was only 130. I needed the regulator anyway.
It will be here Wednesday and then we'll see what happens! (again)
Turbo Build Here
Old 10-08-2012, 02:49 PM
what makes you say that??
i've used these machines and they are pretty much foolproof. there's a few 'common' adapters that simply plug and play, but for other systems there should be a generic harness that supplies power, ground, and whatnot. there are even pichurz in teh manual...
anyway, what did they, *ahem*, "determine"...
df
Old 10-08-2012, 05:52 PM
Needs Boost
Mein Auto: Red Sled
The picture with instructions on their computer looked very different from my alternator so they just guessed on the wires
Turbo Build Here
Old 10-17-2012, 06:05 PM
Needs Boost
Mein Auto: Red Sled
Gauge cluster in and working.
It's hard to hear, but it just BARELY runs after it is a little warm when the idle drops. It sounds like it's missing and of course will die.
Me and a buddy were messing with it tonight and tested the coolant temp sensor wiring, everything checks out. To recap, the car shuts off and won't restart when you plug it in. No wire interference or anything of the sort so we're thinking it must be the computer, right?
Turbo Build Here
Old 10-17-2012, 08:05 PM
hornhospital's Avatar
D'oh, You Kids!
Sounding more and more like it is the 'puter. Can you find a known good one to swap in to see if that's it?
Quotes to live by:
Old 10-18-2012, 05:07 AM
Needs Boost
Mein Auto: Red Sled
I wish I could! Luckily they're not too bad on Ebay, about 60 bucks.
Turbo Build Here
Old 10-20-2012, 06:19 PM
Needs Boost
Mein Auto: Red Sled
Ordered a computer.
Here is a plug btw:
ID:	346598   Click image for larger version
Turbo Build Here
Old 10-20-2012, 07:30 PM
looks to be running rich...they look rather sooty.
df
Old 10-20-2012, 10:54 PM
Needs Boost
Mein Auto: Red Sled
Yes sir!
Hoping this computer helps. If not next is injectors and afm.
Coil tested good, icv is clean and tested good, new distributor cap and rotor as well.
Turbo Build Here
Old 10-25-2012, 03:34 PM
Needs Boost
Mein Auto: Red Sled
Spoiler alert:
It's running
Turbo Build Here
Old 10-25-2012, 04:54 PM
Hellawut??
Mein Auto: who knows?
what was it?
-Franklyn
Old 10-25-2012, 05:32 PM
Needs Boost
Mein Auto: Red Sled
Hooked up the new used computer, checked fuses, and attached all sensors and wires.
Fired right up
She has no issues with no load, but under load it has a mis for sure. Thoughts? New cap rotor and plugs, old wires and old distributor. Entire fuel system is new. Going to try some seafoam tomorrow and see how that goes.
Here is a vid, the second one is weird, the idle goes up and down then eventually settles. Computer adapting or something else?
Stoked!
Turbo Build Here
Old 10-28-2012, 09:43 AM
Needs Boost
Mein Auto: Red Sled
I think it's a spark related miss, the wires look pretty bad. Of course no one had the wires. Oh well they'll be here Wednesday.
Did a lot if work on it the past few days. Replaced almost all the exterior bulbs as most weren't working and the turn signals were acting up. All better now.
Ran some seafoam through it too. I need to do it again and put some in the fuel and oil again. It actually didn't smoke much.
Hooked up the window switches, they had the control wires for the motors themselves, but no power or ground, odd. They work great now!
Then did some hobo floor repair. Cut out the worst rust, then cut and screwed down an old real estate sign.
I finished it up by covering it all up underneath with fiberglass. Later I'll undercoat the top, then the bottom after I sand the fiberglass.
Then I gave the engine bay and under the engine a quick clean. I'm trying to locate my oil leak. I think the majority is the valve cover gasket so I'll have to put one on order.
Pictures will be up soon.
Didn't have as many pictures as I thought lol, I'll have to take some more.
Nasty floor
Before
After
Turbo Build Here
Old 11-01-2012, 04:31 PM
Needs Boost
Mein Auto: Red Sled
Plug wires helped, still misfiring a little.
I'll have to check the plugs and gap tomorrow, maybe it just needs driven more since it sat so long. Or maybe the coil is bad? It tested ever so slightly out of spec. Possibly timing as well?
Turbo Build Here
Old 11-01-2012, 04:34 PM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
bimmerfest Supporting Member
Mein Auto: A redhead E90
it's a miracle.
Originally Posted by Los View Post
^He's been drinking beer and destroying pumpkins with brake rotors and sledge hammers.
So, pretty much just doing man stuff.
  • '06 325xi 6MT
Old 11-01-2012, 04:39 PM
Needs Boost
Mein Auto: Red Sled
You didn't see earlier I had it running? lol Been driving it all week!
Turbo Build Here
Old 11-01-2012, 04:41 PM
Kdoherty's Avatar
ive been around, fighting off hurricanes and crap
  • '06 325xi 6MT
Old 11-01-2012, 04:43 PM
Needs Boost
Mein Auto: Red Sled
Oh yea, forgot about that! (barely did a thing here)
Turbo Build Here
Old 11-01-2012, 04:47 PM
Kdoherty's Avatar
it didnt do much where i live either, i mainly sat around drinking beer and stuff waiting for the power failure that never came. then the next couple a days ive been helping people chainsaw trees
  • '06 325xi 6MT
Old 11-01-2012, 04:50 PM
Needs Boost
Mein Auto: Red Sled
Yea we were very lucky here.
Thoughts on the misfire? Where is DF? Not sure if he heard the good news.
Turbo Build Here
Old 11-01-2012, 04:53 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
He's probably underwater like the rest of NJ.
-CJ
Old 11-01-2012, 04:54 PM
Kdoherty's Avatar
as far as the misfire, it could be lots of annoying crap. buy im leaning towards plug gap/coil. you can also do the wire elimination method, and unplug one wire at a time to see if the miss gets worse or stays the same. if you pull one wire and nothing changes that much, well your problem could be isolated to that wire/plug/coil
  • '06 325xi 6MT
Old 11-01-2012, 05:04 PM
Needs Boost
Mein Auto: Red Sled
True CJ.
I unplugged them one by one and reved it, they all acted exactly the same. I'll run it hard and see what the plugs look like tomorrow. I know number 2 was wet dark looking before I did the wires, so maybe it's still causing the miss.
Turbo Build Here
:3
