Misfire on two cylinders - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 08-05-2012, 12:36 PM
neojamal747 neojamal747 is offline
Mein Auto: 2001 325Ci 2.5L
Hi all,
I drive a BMW 325Ci 2.5L manual.
About a week ago in the state of NJ there was this HUGE storm, i ended up getting caught driving through it. My car got caught in a a little bit of water and automatically shut off. Assuming it was a safety mechanism i pushed the car out of the water and let it sit for about a hour and a half and let it dry out a bit. I ended up being able to get it to start so i finished driving it home (which was only about a half mile away). I noticed the sound change and feel in the car, and i realized it was deffinately because of misfire.
I just left it in the garage for like 4 to 5 days to let it dry out as much as possible and then started it again and went for a drive, same misfire. I used a car MD my cousin had let me borrow and just as i expected, misfire in cylinders 4 and 6. So i decided to troubleshoot by switching around a the ignition coils and such, they were all working, even the ones where the misfires were. So by then i assumed it was just the plugs, i switched out the plug for 4 and then tested by removing the coil while the car was on, nothing....no change at all.
whnever i remove a coil that works the cylinder stops working and the engine shakes more profusely. Let me remind you i switched ALL the coils around and they all worked in other cylinders. i figured out cylinder 6 was just a spark plug problem because when i disconnected the coil the engine shook more. But when i remove the coil for 4 nothing, no change and that coil works in other cylinders and so does the spark plug...So i dont know what else the problem could be.
Anyone have ANY suggestions? im really desperate here. THANK YOU in advance.
Old 08-05-2012, 01:32 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
What are the exact codes the car is throwing?
Old 08-05-2012, 02:49 PM
Exact codes are p1349(misfire cylinder 4 with fuel cutoff) and p1353(misfire cylinder 6 with fuel cut off) and p0300 (random/multiple misfire detected).
Im thinking the most logical thing now is to check the fuel distributors ? maybe it has nothing to ignite?
Old 08-05-2012, 03:38 PM
smolck's Avatar
ROLL TIDE!
Just seems odd that the injectors would screw up because you drove through a puddle. I can tell you that the misfire codes you get with bad coils are 0304, 0306, etc. So I doubt it is coils (as you already discovered). But yes, I would swap injectors if I were you.
Old 08-07-2012, 08:32 AM
It was not the Fuel Injectors, i switched a cylinder 3 and 4 around and no change, 4 is still cutting out. So anyone else have any other ideas? what could be causing this misfire in cylinder number 4? I believe i fixed cylinder six because that was just a spark plug issue. Haven't got to use the car md on it yet but i will be able to on the weekend.
But still cylinder four is not responding at all.
Assuming the integral parts to make a cylinder run are the ignition coil, spark plug and fuel injection...there are no other options that i could try right now at home are there? Maybe compression test?/ but i dont know how to do that...if someone could explain?
Old 08-07-2012, 06:56 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Here are all the ideas in one thread:
- How to diagnose a BMW engine misfire (1)
In addition, I suggest $25 be invested here:
- Cheapest CAN OBDII scanner on the net that reads DTCs, pending codes, & clears codes
Old 08-10-2012, 04:25 PM
I got a Peake R5 code reader. Like many other people said, i used the code reader and checked the codes before resetting the SES light. It turned out the code reader gave out a lot of codes before the reset. After driving around a bit after the reset i checked again and i got 19 and F1. 19 is Ignition coil #1 and F1 is Misfire Cylinder # 4. So still the misfire on cylinder 4. but now when i disconnect the ignition coil i can hear a difference in the engine that i could not before.
So still going to try and figure it out. Now i know the problem isn't too serious though since i can hear the cylinder shut off when i take the coil wire off.
The car drove a hell of a lot better once i cleared the codes. I dont know why, thats so weird. Still open to any ideas! Gonna try replacing spark plug again? idk if that will make a diff but we'll see
Old 08-11-2012, 10:20 PM
Ok wait, another problem arose, disregard the last post. Now the problem only goes away temporarily when i clear the codes. Like i am at full engine power when i clear them and drive. A few minutes later that service engine light pops up and then the engine power significantly drops. Now i am completely lost again. I'm assuming its not TOO serious though? If anyone has any ideas, that would be amazing.
Old 09-08-2012, 02:37 PM
kindya kindya is offline
Mein Auto: 745li
same here
hi hru u did u find the problem? my car is doing the same thing just wondering if u got urs fixed and if so what was the problem how did u fix it....
Old 09-13-2012, 12:00 PM
flipstream flipstream is offline
Mein Auto: 325ci
Any update on this? Have same issue after rain here in Vegas...thanks
