Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Old 08-05-2012, 03:02 PM
rippjd rippjd is offline
Mein Auto: '05 745i / '00 740i
DIY - WeissLicht LED Halo upgrade (Angle Eyes)
I purchased the WeissLicht LHUXX1W2Y LED Halo Upgrade from BavAuto.com for my E65 and took some photos along the way so you can see the difference. These are for the 2002-2005 type headlights.
WL 1: The kit with 2 modules, each having 2 LEDs (supposedly 3W Cree LEDs).
WL 2: Remove headlight and back cap.
WL 3: Comparing old incandenscent bulb to new WeissLicht module. Greasing the o-ring made installation easier.
WL 4: Note the 3 notched openings, one having a more rectangular profile.
WL 5: WeissLicht installed. I only found one side that would allow me to tuck the electrical connection inside.
WL 6: New WeissLicht.
WL 7: Old incandescent bulb.
WL 8: Comparison. Note how the black plastic surrounding the WeissLicht inside the headlight is much more illuminated.
WL 9: Night shot with both WeissLicht's installed.
I did check the current draw between OEM and WeissLicht setup. The OEM bulb drew about 750 mA, while the WeissLicht drew about 500 mA. At 2/3 the power draw, brighter output, whiter color, I say it's a nice upgrade.
Note: I do recommend removing the front bumper, as it makes headlight removal much easier and less likely to break something.
ID:	335591   Click image for larger version
ID:	335592   Click image for larger version
ID:	335593   Click image for larger version
ID:	335594   Click image for larger version
ID:	335596   Click image for larger version
ID:	335597   Click image for larger version
ID:	335598   Click image for larger version
2005 745i Individual
HTML code is Off
