E30 (1982 - 1993)
Old 08-17-2012, 02:23 AM
BmwMan92's Avatar
BmwMan92 BmwMan92 is offline
I <3 my E34
Mein Auto: 1985 318i// 1988 325e
Sending in the morning i have cash so it will be shipped first thing in the morning i set an alarm in my phone lol. I'm so sorry i haven't sent it i've been so busy then i got in an accident yesterday. afm will be headed your way tomorrow!
Brandon
http://www.facebook.com/brandon.m.fore
Originally Posted by v8bimmer View Post
I just dont see any other logical way around this problem.
Old 08-17-2012, 05:09 AM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
That's cool man, thanks! Text me when you ship and I'll Paypal.
Sent from my ADR6400L using Bimmer App
Turbo Build Here
Old 09-12-2012, 06:31 PM
Needs Boost
Mein Auto: Red Sled
New fuel pressure regulator installed, idles now!
Now, have to throw it together for a test drive!
Turbo Build Here
Old 09-13-2012, 07:03 PM
Needs Boost
Mein Auto: Red Sled
Scratch that, not right yet.
Turbo Build Here
Old 09-14-2012, 01:12 AM
BmwMan92's Avatar
I <3 my E34
Did the afm I sent you not help? I know it works I used it on the 318 before I shipped it
Brandon
Old 09-14-2012, 07:33 PM
Needs Boost
Mein Auto: Red Sled
Nah, don't think that's the problem. Fuel issue I believe
Turbo Build Here
Old 09-15-2012, 12:07 PM
BMWFatherFigure's Avatar
Old School
Have you run a pressure check and changed the fuel filter? Looking at what the PO's did to the dash I'm amazed it's even running! I hope you were paid to take it away. I've seen parts cars better than that. Good to see a bloke who loves a chalenge. I saw a AFM fix on another forum (can't remember which) for this style of meter. You do have to have all the bits installed and working before the engine will run properly and it's a pain to establish what the ECM is missing out on. It is always a great feeling to drive your own rebuild. Goog luck.
Current:
E38 Parts Car
Previous:
Old 09-18-2012, 04:09 PM
Needs Boost
Mein Auto: Red Sled
Alright, real fuel pressure updates, sorry for the videos, some are quite long. I did replace the fuel and air filter as well.
To sum, fuel pressure engine off in spec, maybe a hair under.
Fuel pressure engine on, 30 or so psi, spec is 43psi or so.
Turbo Build Here
Old 09-18-2012, 07:07 PM
downhiller's Avatar
livin large
what the timing like and looks like theres a vacuum advance on the distributor. its sounds like in the middle video that theres a miss fire, which to me sounds like bad timing
Old 09-19-2012, 04:59 PM
Needs Boost
Mein Auto: Red Sled
How do I check the timing? I don't think it's missing until very low rpm, were the low fuel preassure just isn't cutting it.
Turbo Build Here
Old 10-25-2012, 06:29 PM
Needs Boost
Mein Auto: Red Sled
She has no issues with no load, but under load it has a mis for sure. Thoughts? New cap rotor and plugs, old wires and old distributor. Entire fuel system is new. Going to try some seafoam tomorrow and see how that goes.
Here is a vid, the second one is weird, the idle goes up and down then eventually settles. Computer adapting or something else?
Stoked!
Turbo Build Here
Old 10-28-2012, 09:55 AM
Needs Boost
Mein Auto: Red Sled
I think it's a spark related miss, the wires look pretty bad. Of course no one had the wires. Oh well they'll be here Wednesday.
Did a lot if work on it the past few days. Replaced almost all the exterior bulbs as most weren't working and the turn signals were acting up. All better now.
Ran some seafoam through it too. I need to do it again and put some in the fuel and oil again. It actually didn't smoke much.
Hooked up the window switches, they had the control wires for the motors themselves, but no power or ground, odd. They work great now!
Then did some hobo floor repair. Cut out the worst rust, then cut and screwed down an old real estate sign.
I finished it up by covering it all up underneath with fiberglass. Later I'll undercoat the top, then the bottom after I sand the fiberglass.
Then I gave the engine bay and under the engine a quick clean. I'm trying to locate my oil leak. I think the majority is the valve cover gasket so I'll have to put one on order.
Pictures will be up soon.
Didn't have as many pictures as I thought lol, I'll have to take some more.
Nasty floor
Before
After
Turbo Build Here
Old 11-01-2012, 05:17 PM
Needs Boost
Mein Auto: Red Sled
New plug wires helped, still has a misfire. Thoughts? Going to pull the plugs tomorrow and inspect and check gap.
Coil maybe? It tested ever so slightly out of spec.
AFM?
O2 sensor?
Turbo Build Here
Old 11-01-2012, 06:54 PM
ForcedFirebird's Avatar
ForcedFirebird ForcedFirebird is offline
Mein Auto: 1986 327is
Compression tested yet?
Wide Open Throttle Technologies (WOT-Tech)
Instagram feed
Facebook page
Old 11-01-2012, 06:57 PM
Needs Boost
Mein Auto: Red Sled
I have not tried that, but it only misses under load. Revs perfect in neutral. I removed each wire one by one and it acted the same between each. Maybe I'll test compression tomorrow.
Thinking I'll put an O2 sensor on it since it's only 16 bucks. The idle can sometimes surge as well. Cleaned the icv already though.
Turbo Build Here
Old 11-01-2012, 09:06 PM
hornhospital's Avatar
D'oh, You Kids!
Injectors clean? That sounds like an injector issue, especially the random misfires.
Quotes to live by:
Old 11-02-2012, 06:52 AM
Needs Boost
Mein Auto: Red Sled
I removed them long ago and soaked them over night. Then I seafoamed it last week.
Turbo Build Here
Old 11-02-2012, 09:28 PM
Needs Boost
Mein Auto: Red Sled
She's running pretty good, almost perfect. New O2 senser helped I think. Slight miss at idle, I believe it's number two because using a temp gun it showed around 75 degrees or more cooler.
Still has the little hesitation under load, but it's much much reduced. I'm thinking it's low compression I'm number two or a bad fuel injector.
Turbo Build Here
Old 11-02-2012, 10:21 PM
D'oh, You Kids!
Soaking won't remove most deposits in an injector, it just loosens them up a little. It really needs to be ultrasonically cleaned (preferably multiple times) and have cleaner run through it from both directions. I used WitchHunter Performance for the M30 injectors I sent off today because I'd used them before and had excellent results. For $21 per injector (plus $10 flat rate return shipping), it's a bargain IMO.
Quotes to live by:
Old 11-10-2012, 04:49 PM
Needs Boost
Mein Auto: Red Sled
Could my factory M50 injectors work or would it cause it to run incorrectly due to too much fuel?
Carpet on the way! 125 shipped.
Need to dye it and my door panels black.
Turbo Build Here
Old 11-10-2012, 05:39 PM
D'oh, You Kids!
I think the M50 injectors are a difference impedence that the OEM M10 injectors, and won't work, or work poorly.
What dye are you using?
Quotes to live by:
Old 11-11-2012, 12:14 PM
Needs Boost
Mein Auto: Red Sled
Not sure Ken.
Dye suggestions?
Turbo Build Here
Old 11-11-2012, 12:59 PM
D'oh, You Kids!
Rit, believe it or not.
http://www.ritdye.com/
Quotes to live by:
Old 11-12-2012, 05:28 PM
Needs Boost
Mein Auto: Red Sled
I'll check it out!
Here is my hobo floor lol. Used bedliner spray on top. I'll probably do the other side tomorrow then undercoat the bottom of the car. Sorry for being dark.
ID:	349329   Click image for larger version
ID:	349330   Click image for larger version
Turbo Build Here
Old 11-13-2012, 12:15 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
I think this a splendid idea
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
