Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 01-04-2013, 06:37 PM
FenderBender's Avatar
FenderBender FenderBender is online now
Needs Boost
Mein Auto: Red Sled
Which temp switch is that?
Sent from my SCH-I605 using Bimmer App
Turbo Build Here
Parting Out Complete 96 328is
Old 01-04-2013, 06:44 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Originally Posted by First time View Post
The temp switch that Is being mentioned is located closest to the FPR and closet to the valve cover (yellowish looking) here are the resistance values:
14 +/- 2 degrees F: 7000-11600 ohms
68 +/- 2 degrees F: 2100-2900 ohms
176 +/- 2 degrees F: 270-400 ohms
^This. The one First time is talking about, closest to the fuel pressure regulator.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 01-04-2013, 06:55 PM
ForcedFirebird's Avatar
ForcedFirebird ForcedFirebird is offline
Mein Auto: 1986 327is
Sounds like a vacuum leak.
The 1986 325es Delphin project LINK
Project 1988 325i sedan "Pinky" LINK
Old 01-04-2013, 07:17 PM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 1984 318i
Well seing as he said the idle is the ony issue now i am going to rule out a vacuum leak. The idle varies he states so its not plausible that a vacuum leak would appear then disappear at will. Something else is playing up.
First time's Avatar
And your certain the AFM you recieved is still within spec?
Old 01-04-2013, 07:38 PM
Needs Boost
Mein Auto: Red Sled
I can swap another in but I did that before the new iac with no change.
Turbo Build Here
Old 01-04-2013, 08:04 PM
First time's Avatar
So you have tested the temp switch already?
Old 01-04-2013, 08:33 PM
Needs Boost
Mein Auto: Red Sled
No I was talking about the afm.
I put a brand new temp switch in just a few months ago though. I'll see if I can test it tomorrow.
Turbo Build Here
Old 01-04-2013, 08:39 PM
First time's Avatar
Oh ok well i suppose checking the temp switch would hurt as sometimes new units can be defective.
However about the afm, not to take away from the sellers statement of it working fine. It is old just like yours and would hurt to test it also.
On the fuel side of things there are a few different sensors and switches that make all the magic happen. Troubleshooting, while tedious work, can be enlightening.
Old 01-04-2013, 08:41 PM
Needs Boost
Mein Auto: Red Sled
The afm testing is inconclusive. Both tested exactly the same. Car is running pretty good. Another member said he bought a refurbished one that tested just like mine and his car doesn't have any issues.
Ugh
Turbo Build Here
Old 01-04-2013, 10:08 PM
First time's Avatar
How are you testing it other than plugging it in?
Old 01-05-2013, 05:25 AM
Needs Boost
Mein Auto: Red Sled
I have a video of it in this thread I think. Looking for a slow rising of resistance by opening the door slowly. Neither of them have a slow steady rise they are jumpy. But like I said another guy told me his refurbished unit did the same thing.
Turbo Build Here
Old 01-05-2013, 05:38 AM
SWISS's Avatar
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
How does the engine respond when you press the throttle? Do the RPM's dip any or bounce when you let off and it settles?
I still think it's getting un-metered air and hitting it's adaptation limits. Ie vac leak, if it's large enough you can remove the oil cap when running and it won;t change a thing. Sealed up crankcase will choke and die if you pull the cap off.
Old 01-05-2013, 08:49 AM
First time's Avatar
Ahh ok sorry i didnt look at the video. My afm did the same thing upon testing it. I too have a '84 318i. However my car idles around 900. I have not set timing to spec though so that's my excuse. My car idles perfect at 900 no bouncing at all.
I luckily had two M10's laying around to pick parts from. I have replaced the cap and rotor, plugs and wires, O2 sensor, fresh oil and filter, new coolant temp switch.
My car runs decent (i have never heard of these M10's running perfectly)
Old 01-05-2013, 08:51 AM
First time's Avatar
Swiss could be right about a very small amount of air. Check the oil cap and the oil dipstick for leaks. Maybe you can push down on them while the engine is running and give the engine a rev or two and see how it settles again.
Old 01-05-2013, 03:49 PM
Needs Boost
Mein Auto: Red Sled
Alright, well I fiddled a little with the car today. While running, I unplugged the coolant temp gauge (almost brand new) and it idled way down, almost died but not quite. I would believe that that means I have no major vac leaks.
Plugged it back in and the idle went right back up. Then I unhooked the AFM and it all but died, then plugged it back in a the idle was good then.
Maybe I should unhook the battery and let everything reset
I had a VCG laying around so I decided to powder my valve cover, came out pretty nice I think.
Wrinkle red was the color choice. First wrinkle I've done. You can see the oil cap came out differently than the valve cover. Different metals?
Turbo Build Here
Old 01-05-2013, 07:50 PM
First time's Avatar
Looks good. Albeit very bright. I noticed you still have the fuel damper on the line running towards the fpr. I did away with that stupid thing.
Old 01-05-2013, 07:51 PM
First time's Avatar
What rpm does your car idle at? And is it still bouncing around or is it a steady but high idle?
Old 01-05-2013, 08:18 PM
Needs Boost
Mein Auto: Red Sled
What does that piece do?
The last time I started it after I fiddled with it the idle was around 850 rpm.
Turbo Build Here
Old 01-06-2013, 12:57 AM
First time's Avatar
That thing just corrects the differences in the fuel pressure. There is one on the outlet side of the high pressure fuel pump too. Seeing as the lift pump (in tank) is a high volume low pressure pump and the other pump (chassis mounted) is a high pressure low volume pump the dampers are placed in order to keep fuel flow and pressure under control and have it at somewhat of an equilibrium if you will. But thats what the FPR is placed for. I have removed mine (most have) because they can become clogged with debris. Havent had any issues since. This was three years ago.
Old 01-06-2013, 05:35 PM
Needs Boost
Mein Auto: Red Sled
What did you do, just remove it and insert a long tube with clamps or replace the whole line? My whole fuel system is new, has the newer style E30 fuel pump, deleted the secondary one.
Should I get this??
http://reading.craigslist.org/cto/3522643622.html
Turbo Build Here
Old 01-06-2013, 05:48 PM
First time's Avatar
Yes i replaced the entire line. That 325i looks like it has a nice interior and somewhat nice body. Looks like some rust on the quarters (luckily i live in cali so i dont have to deal with rust)
However he doesnt say what is leaking. Idk the condition of your car but if your looking for mpg then just stick with the 318i.
Old 01-06-2013, 05:51 PM
Needs Boost
Mein Auto: Red Sled
I'd be keeping the 318 for a while, I want a 4 door eventually though.
Turbo Build Here
Old 01-06-2013, 05:56 PM
Needs Boost
Mein Auto: Red Sled
4 door would get a stick and an M52 most likely.
Turbo Build Here
Old 01-09-2013, 06:15 PM
Needs Boost
Mein Auto: Red Sled
I think I may have figured at least one issue out. I was fiddling with the car, check the TPS (PITA, couldn't really tell if it was ok or not) and checking for vac leaks. I hear a slight hissing noise near the firewall all the time but I can't seem to pin point it. Anyway I was moving wires around, and the fuel return line when the idle started changing. So I moved the return line and sure enough, changed the idle, if I move it a certain way, it will die. If I move it another way, it will idle right at 700 rpm. Part of the line is almost rock solid.
So tomorrow I'll replace that whole line and see what happens.
Turbo Build Here
