Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Car Audio & Electronics Forum
Hi-Fi upgrades, XM Radio, Sirius, Bluetooth, and Radar Detector discussions here!
Old 08-05-2012, 10:59 PM
Jsborn Jsborn is offline
always learning...
Mein Auto: 2002 M5 (soon)
Using two Valentine Ones?
I recently purchased two V1 detectors on eBay, one v1.8a-POP2, the other v1.8-POP2. The first one doesn't have the crystal-safeguarded band limits but is otherwise identical to the second.
Long story short, the second auction ended in the middle of the night (poor timing by the seller--I think they autolisted with an AM instead of PM time) and I won with a low bid.
In any case, my question: I have a cross-country trip coming up and am considering using both detectors. Why? To see which one I prefer and (hopefully) get even better coverage. Can anyone tell me whether one V1 adversely affects another in close proximity?
Also, any tips/suggestions for running two detectors? I am hardwiring into my sunroof/light control for the long haul, so one will be hardwired, the other will be powered from the 12v socket.
Now: '02 M5 carbon/black, Dinan S3 susp/sways/bars/camber/exhaust/wheels, UUC SSK, MKIV nav, iPhone 4S cradle
Ex: '07 335i 6mt sport, BMW susp/exhaust | '06 MX-5 w/ LSD | '96 ZX6R | '95 M3 w/ stiffness mods | '95 325is Dinan S3
Old 08-10-2012, 08:25 AM
RichardP RichardP is offline
Mein Auto: BMW E39 M5
So long as you don't have the Climate Comfort screen there should be no problem running two V1's. If you do have the CC screen then the mounting points are very limited, the V1 must be mounted so it looks through the cutout behind the rear view mirror otherwise the metalic laminate will block about 95% of the radar signal.
2003 M5, Carbon Black, Nav, Intravee II with Ipod + MP3 CD Changer + DAB + MD Changer, TV, Bluetooth Phone, the works.
Old 08-10-2012, 10:45 AM
beewang's Avatar
beewang beewang is online now
Bo-ma-win!
Location: Eugene, OREGON, Home to the Rose Bowl Champion
Send a message via Yahoo to beewang
Mein Auto: S62 E39
Actually, I think you will have an issue w/ interference when you put 2 V1's next to each other. But I think you will know that pretty quickly on your trip.
Old 08-10-2012, 09:43 PM
KeepRt.PassLeft KeepRt.PassLeft is offline
Mein Auto: 2005 325cic
Do not use two V1 in the same car. They will interfere with each other, causing significantly reduced or missed warnings.
Old 12-08-2012, 07:58 PM
bose13 bose13 is offline
Mein Auto: 535i
v1
use only one they are so good that is all you will need, v1's are the best don't use two of them.
