Old 08-07-2012, 11:02 AM
chirag11 chirag11 is offline
Mein Auto: 2004 BMW 525i
2004 525i - heavy steering after new tires
Hello
I just got the tires replaced on my 2004 525i.
After doing that, the steering feels a lot heavier than it used to. It was a bit heavy already, but not such that it required much effort. Now I constantly feel that I need to put effort to just change lanes.
I am also in need of an alignment I think (car pulls to right - tires replaced just last week). But the steering issue became noticeable after the tire change.
I have been reading lots of threads and here is what I gather:
1. Do the alignment.
2. Top off Power Steering Fluid - which I understand is actually ATF - is this the correct thing to use: http://www.amazon.com/Pentosin-Suspe...qid=1344358224
Amazon tells me it is not... but as per other forums Pentosin CHF 11S is the right thing
What else can I check to ensure its not something else?
Old 08-07-2012, 11:34 AM
bimmerfan52 bimmerfan52 is offline
Mein Auto: 545i
Originally Posted by chirag11 View Post
Hello
If the old tires were significantly worn then they may have offered less resistance to the car's mis-alignment. You probably worn the tires severely on the inside edge. I think what you are feeling with the new tires is the newly flat treads offering resistance to being "rolled over" or tipped to match the mis-alignment angle.
Get the alignment immediately.
RE: Power Steering Fluid
The correct power steering fluid (which depending upon if you have the sport suspension is shared with the active roll stabilization) is shown on the filler cap of the power steering reservoir. Use only what is noted on the cap.
For a 2004 525i, unless you know the PSF system has received preventive maintenance before, you should consider flushing the system and installing a new power steering fluid reservoir (which has a filter integrated into the reservoir). If you are a DIY, or if you are having an Indie who may not be familiar with the procedure do the work, I have attached the manufacturer of the power steering rack's flush procedure.
File Type: pdf ZF Procedure Flushing Power Steering System.pdf (10.6 KB, 95 views)
Old 08-07-2012, 11:47 AM
Bimmerfan52:
Thanks a lot for your input. I will get the alignment done this week...
I did have the power steering flush done about 2 years ago. If its not expensive, I would have it done as well. I will be going to an indy shop. Dealer rips off way too much.
Thanks again!
Old 10-13-2012, 01:52 PM
BimmerRules! BimmerRules! is offline
Mein Auto: 2012 535xi, E-46 zhp
Bimmerfan52:
Thanks again!
I am curious...how much did the dealer charge to do your power steering flush 2 years back?
Thanks,
